No parasitic draw, battery still drains. - Hemi Truck Club
Old 05-19-2016, 01:05 PM   #1
Truck of the year 2014
Belgiquebasterd's Avatar
Hey guys, asking this question for a friend with a hemi (dodge magnum).
When he doesn't drive his car for a week, the battery is empty (5v). I tested for parasitic draw with my amp meter inbetween the negative battery pole and the disconnected negative battery cable and found a 'parasitic' draw of 24mA. According to google and EricTheCarGuy :-), this is what's to be expected of a car, used by clock, pcm,... when the ignition is off. So there seems to be no excessive parasitic draw?
Now for the question, if there is no parasitic draw, what could be causing the drain? Battery has recently been renewed and voltage goes up when the car is started so I think the alternator is also ok.
Thanks.
Old 05-19-2016, 01:19 PM   #2
Renewed? Replaced with a new one? The battery itself may be junk have seen it before they loose voltage just sitting for some reason.
Old 05-19-2016, 02:16 PM   #3
Sorry for the confusion, yes a brand new battery. Installed after the first time he let his car sit for some time, hoping that a bad battery was the cause. Unfortunately it was not.
Old 05-19-2016, 02:21 PM   #4
Hmmmm. Magnum battery drain unknown reason! Does it have the little black door lock buttons on the handles to the car? Is it a fob or a key to start car?
Old 05-19-2016, 02:37 PM   #5
It's a key to start the car, but looks to have a chip inside. The lock buttons you mean on the small instrument panel on the inside door handle? If so it does.
Old 05-19-2016, 03:30 PM   #6
No these buttons would be on the outside door handle so it likely doesn't have it to early a car. Ok radio is it stock or aftermarket?
Old 05-19-2016, 03:30 PM   #7
Check the battery for any kind of film, or dirt running from battery terminal to battery terminal. I learned many years ago that this will also slowly drain a battery's voltage.
Old 05-19-2016, 04:10 PM   #8
Also you might check to see if the hood light goes out when closed. I had a vanity light (sunvisor) that stayed on and couldn't be seen. Same with the glove box. Accessory outlets clean? And last disconnect the battery and see if it drains or not.
Old 05-19-2016, 05:16 PM   #9
hemiram13's Avatar
There could also be a module that decides to "wake up" when it wants to.
2013 RC Express HEMI
Old 05-19-2016, 06:26 PM   #10
David
ATXHEMI's Avatar
My visor light is always on. My truck sits all week and doesn't drain the battery.
