Lifters - Hemi Truck Club
Old 02-09-2018, 10:35 AM   #1
Lifters
Which cylinders get mds lifter on 5.7 hemi?
Deaton17 is offline   Reply With Quote
Old 02-09-2018, 10:53 AM   #2
ric3xrt's Avatar
Driver's side bank 1st and last cylinder, passenger side bank 2nd and 3rd,
NON- MDS lifters should be the only ones that fit in their slots in the MDS yokes. the MDS lifters are wider when you measure them from flat surface to flat sureface.
04 GTX...Under the Knife.
Old 02-09-2018, 10:56 AM   #3
Thanks. Another question. Do you know why my exhaust rocker arm shaft bolts keeps coming loose?
Old 02-09-2018, 11:03 AM   #4
ric3xrt's Avatar
here's the front and rear MDS yoke, the MDS lifters will only fit in the part marked MDS,
When you install both yokes in their designated position, on either side of the engine it will place the MDS lifters in their correct spot.
Old 02-09-2018, 11:07 AM   #5
ric3xrt's Avatar
Not sure but I've read on LX forum that a few people had issues with the rocker stand it's self cracking on 09-10 5.7s ,
does the bolt tighten up to spec or does it keep turning as tho it's stripped?
Old 02-09-2018, 11:08 AM   #6
No they get tight. Scared to use loctight
