Intake valve - Hemi Truck Club
Old 12-25-2016, 01:54 PM   #1
Intake valve
So found out have no compression on cylinder 1 pulled valve cover broken intake valve spring cannot get cylinder to seal in order to change it does that mean valve bent
Mikeyshea0523 is offline   Reply With Quote
Old 12-25-2016, 02:32 PM   #2
Ok, it's making more sense now. I usually put a nylon wire tie around the valve stem to prevent it from dropping into the cylinder. Pushing the stem down maybe a half an inch and then lifting the stem quickly to slap the valve onto the seat it makes a solid dull thunk, if you don't get that solid thunk, then the stem is bent. But not being able the seal the cylinder with air is also a very good indicator it's bent. I'd recheck it again and if the results are the same then it sounds like the head needs to come off.
Old 12-25-2016, 05:40 PM   #3
Sounds like it's a bent issue for sure sadly the head will likely have to come off
Old 12-25-2016, 10:01 PM   #4
Gary
leadfoot's Avatar
When I broke a valve spring the valve dropped into the cylinder and got crushed when the piston came up. Had to remove both heads and had them redone.
Old ride
03 ram quad cab hemi
New ride
2013 Ram Crew Cab Sport
No Mods
