i have no power! - Hemi Truck Club
Old 01-03-2017, 04:48 PM   #1
i have no power!
i have a 2003 ram 2500 with the 5.7 hemi. i just put in a slightly built motor( i blew up the old one) and now i have no power. the dome light and headlights work but no cluster and no start no response to turn of key (all fuses are good). i grounded everything to see if that would help. but it didn't change anything. i am open to any and all ideas thanks in advance.
huntmaster56 is offline   Reply With Quote
Old 01-03-2017, 05:11 PM   #2
Did you attach the ground straps to the rear of the heads?
Do you have the ASD relay plugged in?
Old 01-03-2017, 05:13 PM   #3
yes i grounded valve covers to head heads to block both heads together and block to frame
Old 01-03-2017, 06:08 PM   #4
That sounds like it should be enough. The original just had braided ground straps from the back of the heads to the cab. Will need to see if power is being fed from the IPM. Do you hear the fuel pump run with the key turned on . Did the truck run before you changed engines?
Old 01-03-2017, 06:09 PM   #5
Make sure engine ground wire from battery is there the big cable drivers side near front cover area. Also you didn't pinch the harness in the middle of the trans and engine did you seen that before
Old 01-03-2017, 07:24 PM   #6
yes truck ran till i spun the bearings no fuel pump is not priming
Old 01-03-2017, 07:25 PM   #7
harness is not pinched and the ground is attached
Old 01-03-2017, 07:31 PM   #8
Dead battery? Looks like you will just go step by step until you get no power. Was the IPM taken out for any reason?
Old 01-03-2017, 07:33 PM   #9
battery has 12.34 volts no the ipm wasnt removed im thinking possibly ignition but i dont know how to test that
Old 01-03-2017, 07:47 PM   #10
If all is good and now it simply won't start that's the only likely culprit besides the time taking a crap.
