I can't find it... - Hemi Truck Club
Like Tree6Likes
  • 3 Post By Redtruck-VA
  • 3 Post By SUPER BEE
Old 02-04-2019, 03:32 PM   #1
Gila Hemi's Avatar
I can't find it...
I have a 2004 2500. I also have an extreme pack rat problem where I live. That said, I just started getting an occasional check engine light, and determined that a low oil pressure indication was causing it (it only lasts for seconds). I suspect the %$&*%$#@% pack rats as the cause of the problem in spite of my anti-pack rat measures. I have a full set of manuals for my truck and been through them from top to bottom more than once. What I cannot find is the location of the oil pressure sensor and where the wiring from it to the PCM is located. This is too serious of a problem to put up with, as I want to know what my oil pressure is at all times. Can anyone help with this?
Thanks
Old 02-04-2019, 03:55 PM   #2
Here's a picture.
Old 02-05-2019, 09:42 AM   #3
Tyler
TYSENUS's Avatar
I added an oil pressure gauge and plumbed it in a "T" with the factory sensor. The factory sensor is nothing more than a dummy light that turns the gauge in your dash on at 7 psi but you need to keep it happy or have a check engine light on, so I run both.
Mods:
Old 02-05-2019, 09:52 AM   #4
Yep, at one time I had a little mini gauge screwed into a tee so I could check idle pressure.
Old 02-05-2019, 01:17 PM   #5
I did the same thing since I consider oil pressure and tranny fluid temp. very important. I still have my dash oil pressure gauge working.
TYSENUS, kcd1369 and Redtruck-VA like this.
Old 02-05-2019, 02:52 PM   #6
Gila Hemi's Avatar
Thanks for the help! I have a small fuel pressure gauge that I used under the hood on my Challenger until I installed one in a pod on my overhead console. I wonder if it would work for oil pressure on my Ram? I don't believe I have an oil pressure problem, but this is bugging the heck out of me.
