Hemi new intake not same as old one. more???'s - Hemi Truck Club
Old 01-28-2017, 02:13 PM   #1
327
Ok, so this SHOULD be my last round of questions.
I have a nonEGR 03' dodge truck.
Ordered a new intake from RockAuto. Its obviously an EGR intake.
No matter. I made a plug.
The question is the Foam insert. The original Foam insert that fit the original intake will not fit the new intake.
I went to install the new intake, and it sat up about 1/4" to high, because it wont mesh with the old foam insert.
There want any foam insert that came with the new intake (even though it said on the site that it does).
So, questions? How do I make my old foam fit the new intake?
WTF is this foam insert for anyways?
Can I just pitch the foam all together?
327 is offline   Reply With Quote
Old 01-28-2017, 03:08 PM   #2
I think it's there to keep squirrels out. I don't use one, but I use a different manifold. If you can cut on it a little to make it fit I'd probably re-use it. Otherwise I'd toss it.
My 2 cents...
Old 01-28-2017, 03:29 PM   #3
327
What intake do u use? Ya if this is just a pest barricade, ill make my own.
Old 01-28-2017, 03:35 PM   #4
ric3xrt's Avatar
Greg(aka) Redtruck VA) uses an OCP dual plane .
Old 01-28-2017, 03:53 PM   #5
I only said that because all I've ever found under the manifold is nut shells. Good old country living....
Old 01-28-2017, 04:30 PM   #6
Matt
MANual_puller's Avatar
It's insulation to help keep heat soak to a minimum. It's not for pests as they can just burrow right through it in a minute flat if they wanted. I would definitely try to get it to work.
Old 01-28-2017, 04:42 PM   #7
Spoiler! I thought pest deterrent was a good answer. At least in my neighborhood....
Old 01-28-2017, 04:47 PM   #8
Matt
Well, there's no reason you can't lace it with something while it's out.....
Old 01-28-2017, 05:48 PM   #9
327
So its insulation?
Is there any place out there that sells these? If its that important, id rather just buy the proper one.
Ive tried various search terms, but not having much luck.
Old 01-28-2017, 06:12 PM   #10
327
I have plenty of Mylar I could put in there. Kinda seems a better way to go than the foam anyhow.
