Hemi Dakota Cruise Control VSS1 and VSS2 signals - Hemi Truck Club
Old 09-12-2020, 07:26 PM   #1
I am back to working on my Cruise Control circuit on my 02 Dakota Hemi swap. Looking at the Ram ECM and ABS circuit there are 2 VSS signals from the ABS to ECM. The Dakota ABS only has 1 VSS signal. I got an oscilloscope so I can see the VSS 1 signal and here it is. Some people suggested that I could use VSS1 and VSS2 by connecting them together but when I tried this the truck would barely run over 60mph. I can connect my DRB3 to the ECM and see the speed sensor working and I can see the CC buttons signals change when I press a button the Ram steering wheel.
I need to know what is the VSS2 signal supposed to look like? Is a square wave signal like VSS1?
I have an electronics degree so I think I can build a signal duplicator circuit if I just knew what is supposed to look like.
The only other option I was looking at was to add the wheel sensors on the front 2 wheels, change the wheel bearings to the ones with the tone ring and use a 05 Ram ABS module, I actually bought the ABS module last week before I got to thinking that I can beat this issue with electronics.
What do you guys think?
02 Dakota QC 5.7 Hemi swap
06 Dodge 3500 Cummings
18 Jeep GC
Near Birmingham AL
derek502 is offline   Reply With Quote
Old 09-12-2020, 07:33 PM   #2
I like it when a simulator can be used but in this case I think replacing the wheel bearing with a tone ring style would be the better route.
