Help-I think i ate a cam - Hemi Truck Club
Old 03-14-2016, 06:31 PM   #1
allan
After all the info i've gotten from just reading here the past few months, I'm sure i'm in the right place. Ive got a 2010 RAM 2500 4x4 crew cab 5.7 with a 111k miles. I got it at 106k so haven't driven it that much. I changed the oil at 110k with Pennzoil platinum 5w20 and a K&N filter. About 800 miles later i started getting a minor tick that seemed to be on the right side. It was minor but noticeable to me since it had been totally quiet up til then. Over a couple of weeks it kept getting louder. The engine light came on and had a P0308 code and developed a miss.I reset it and it was just a few miles it popped back on. Since it had been 45k since it had plugs I picked up a set of OE NGK's to install over the weekend and try a different oil and filter combo. On friday before doing plugs it started missing worse and when under a strain had a muffled popping sound in the exhaust and lost power. I was just down the street so i eased on home.
When changing plugs i pulled the right side valve cover since it was easy with air filter and coil packs off. The #8 exhaust rocker is loose enough to slide front to rear enough to almost come off the top of the valve stem. When i turn the engine by hand it barely moves up and down. Its about 1/4 the lift of the other 3 valves. Valve springs look good. I removed the exhaust rocker assembly and just put thumb pressure on the pushrods and there is still very little movement when turning the engine. Doesn't this sound like a lobe worn off the cam? I'm sorry this is so long but i wanted to list all the info i could think of. Any other ideas?
mtntop7460 is offline   Reply With Quote
Old 03-14-2016, 07:11 PM   #2
I am not a Hemi expert so take my advise with a grain of salt, i would look for a collapsed lifter first
Old 03-14-2016, 07:18 PM   #3
Do you still have the filter that you replaced? If so you might cut it open and see if there is any metal showing.
Old 03-14-2016, 07:44 PM   #4
Matt
MANual_puller's Avatar
Along those lines it wouldn't hurt to cut the filter open that's currently on there. Filters are cheap.
Hopefully it's not major!
Old 03-14-2016, 07:55 PM   #5
allan
Going to check filters and oil tomorrow. Hoping for lifters or something less drastic. Thanks.
Old 03-14-2016, 09:27 PM   #6
Since your truck is a 2500, does it have VVT or MDS? If it doesn't then a cam change is not difficult.
Old 03-14-2016, 10:05 PM   #7
Matt
VVT yes, MDS no.
Old 03-14-2016, 10:37 PM   #8
I know little about the newer models, but the VVT replacement cams seemed very pricey. If it is a cam, you might check the various hemi speed shops who do a lot of cam swaps and see if you can get a take off.
Old 03-14-2016, 11:28 PM   #9
allan
But the non MDS lifters are cheaper. Not enough to offset the cam price but hey, Im trying to make myself feel better. I found a you tube video of a guy spinning a motor over that had a bad cam. It was identical to mine so I'm not optimistic. I'll do some more looking at it in the morning to try to make sure.
Old 03-15-2016, 04:53 AM   #10
Sounds like a lobe or lifter to me from the steps you went thru already. Drainage coolant and remove that head and have a look at the lifter in there! Either the wheel is going to be gone and maybe the cam is good still or the cam is shot and you need a new one. If the can has any score marks on it change it out it will get a ton worse fast.
