heater fan keeps running - Hemi Truck Club
Old 08-21-2016, 02:04 PM   #1
Hello everyone, I searched threads for this topic but found nothing. My heater fan keeps running even with the truck off and the key out. I replaced the ignition switch and it did not solve the problem. There was no charring on the contacts as some have noted this may have caused the problem. Someone else mentioned that it could be the resistor on the fan motor itself. Seems unlikely as it should not get power to the resistor if the key is out. Before I go and buy another part does anyone have any suggestions? It is a 2005 ram 1500 with the Hemi.
dcard1 is offline   Reply With Quote
Old 08-21-2016, 02:46 PM   #2
update
actually another question. I can find the blower motor resistor. Its under the passenger dash, is $30 and easy to replace. The questions is where do I find the blower motor relay? It is not in the fuse box under the hood. I removed every resistor in the box under the hood and the fan continues to run without the keys in it.
Old 08-21-2016, 05:44 PM   #3
The ignition switch supply's the power on our trucks. So something has to be wrong in there. The weird part is you said you changed it. If you unplug the switch does the blower go off?
Old 08-21-2016, 06:41 PM   #4
dcard1
Old 08-22-2016, 02:31 AM   #5
boedacres's Avatar
fuse block for an 05 shows a relay
Old 08-22-2016, 05:13 AM   #6
On my 2005 that's the Condensor fan relay not the blower. The SRT10 has a blower relay there not a normal v8 truck. The 2005 is ignition switch controlled power
Old 08-22-2016, 08:24 AM   #7
