Harmonic Balancer Question - Hemi Truck Club
Old 09-28-2017, 01:21 PM   #1
oldmanram's Avatar
Hi,
So I own a 2003 RAM 5.7 , and am rebuilding a motor for it, using a 2006 5.7 JEEP block , problem whoever took off the old harmonic balancer chipped a piece of it off, so I want to replace it. BUT do I replace it with a 2003 or a 2006 harmonic balancer ?, the original 2003 OEM number is no longer used.
Will ANY pre 2009 truck balancer work ?
thanks again for your input !!!
Old 09-28-2017, 01:34 PM   #2
oldmanram's Avatar
FYI
On Ebay they show the 03-04 balancer as well as the 05-08 balancers, so what is the difference ?
I am using an 06 RAM timing cover, if that matters ........
Old 09-28-2017, 01:45 PM   #3
Main thing is make sure it's a truck balancer shoot for 2005-8 range and you will be fine.
Old 09-28-2017, 02:44 PM   #4
RockAuto has listed 03 dodge ram 1500 5.7 harmonic balancer (2) remaining
Old 09-28-2017, 03:34 PM   #5
oldmanram's Avatar
That's a DAYCO , are they any good ?
Better than Dorman ?
Old 09-28-2017, 03:42 PM   #6
oldmanram's Avatar
It's a... PB 1681 N premium
?? PB = PowerBond ? N = nodular iron ??
Anyone used a Dayco ?
Old 09-28-2017, 03:46 PM   #7
oldmanram's Avatar
This is the info on the unit ...........
PB1681N
Premium
PowerBond™ OEM replacement harmonic balancers offer the professional engine rebuilder or shade tree mechanic the highest quality product in the automotive aftermarket.
Features:
Spheroidal Graphite iron casting which is considered near-steel strength material.
Inserted and pressure-bonded rubber that produces rubber strength that is stronger than competitive balancers.
Overall Outside Diameter (in) 7.225
Overall Outside Diameter (mm) 183.50
Crank Bore (in) 1.475
Crank Bore (mm) 37.45
Overall Width (in) 4.634
Overall Width (MM) 117.70
Nose Outside Diameter (in) 0
Nose Outside Diameter (mm) 0.00
Ring Width 1.260
Ring Width (mm) 32.00
Bolt Hole Quantity 3
Crank Trigger/Exciter Plate No
Woodruff Key Included No
Hardware Included No
Counterweight Balance Neutral, no counterweight
Timing Marks No
Installation Instructions Included No
Number of Integrated Pulleys 1
Pulley 1 Type Serpentine
Pulley 1 Outside Diameter (in) 6.989
Pulley 1 Outside Diameter (mm) 177.50
Pulley 1 Number of Grooves 7
Outer Ring Material Cast Iron
sound like it will work ?????????
Old 09-28-2017, 03:48 PM   #8
I would expect them to handle normal useage without issue. If you need high performance then go with ATI. Their balancer will handle whatever you throw at it.
Old 09-28-2017, 06:39 PM   #9
oldmanram's Avatar
So I did some research about the balancers for the trucks on rockauto.
They call for the same balancer 2003-2008 for 5.7 RAM trucks,
Dayco PB1681N
However the JEEP 5.7 balancer is a little smaller diameter , and a little shorter but the crank diameter is the same.
Sooooo , putting a truck Balancer & Timing Cover on a jeep motor should work to line up the pulleys on my ram .............
Make sence ????? anybody ?
Old 09-28-2017, 06:58 PM   #10
Are both front covers the same? Ram Jeep?
