Exhaust manfold bolt size ? - Hemi Truck Club
Old 01-25-2017, 07:40 AM   #1
Anyone know the size of the bolt for the factory exhaust manifold ?
I got time today to tackle the broke exhaust manifold bolt. I pulled off the manifold and the only bolt that was broke was passenger side 1st one by the firewall. I tried welding a nut but it wouldn't take, so i decided to use a left hand drill bit. No wonder it wouldn't weld, it appears as if the manifold had been off before and someone filled the bolt hole with aluminum ! I drilled and tapped it enough to hold. Wonder why someone would do that ? I thnk i am gonna helicore it
_________________________
Old 01-25-2017, 08:44 AM   #2
Weird who does that should have been a steel bolt broke if sitting there.
Old 01-25-2017, 08:48 AM   #3
Yeah it is weird, never saw that before. 1st thought was someone botched a broke bolt removal and sealed the bolt hole up but I don't see any signs of that
Old 01-25-2017, 03:44 PM   #4
You will have to determine the best length for your application. Different manifolds require different lengths. OEM length bolts are too long for header flanges.
Old 01-25-2017, 03:53 PM   #5
I think i am just gonna put on a set of shorty headers. Where are the best deals ? Or does anyone here have a set they want to sell ?
Old 01-25-2017, 04:11 PM   #6
You might try any of the forum sponsors. Can't go wrong..
Old 01-25-2017, 07:42 PM   #7
Thanks. On the hemi what primary size works best 1 5/8 or 1 3/4 ? Basically me ne is a 4wd with cai and a flowmaster
Old 01-25-2017, 08:08 PM   #8
It's pretty much accepted the smaller diameter provides better lower end torque, the larger for higher rpm range. I would recommend using a torque cam. If you put the wrong cam in you will defeated it's purpose.
Old 01-26-2017, 04:51 AM   #9
Thanks Greg, I was looking at the pacesetter mid length headers, are these a direct fit with the factory collectors ? I know the shorty one are but not sure about the md length
Old 01-26-2017, 06:18 AM   #10
I am no doubt out of the loop, but I believe they basically come in two styles. Shorty's and long tube. Shorty's replacing the stock manifolds and LT requiring a little more fabrication. It is easy to run two cats on the LT and Y pipe. You can cut a section from the Y pipe the length of the cats and weld them in. This places them just above the cross member.
