Engine won't turn over - Hemi Truck Club
Like Tree1Likes
  • 1 Post By charged392
Old 06-14-2019, 08:23 AM   #1
Got in the truck yesterday, turned the key and all I had was clicking solenoid sounds of a dead battery(battery 3 mos. old). Put it on the trickle charger overnight. Tried to start it again... clicky click again. No DTC codes to speak of. Any suggestions?
dogzebra is offline   Reply With Quote
Old 06-14-2019, 08:48 AM   #2
Old 06-14-2019, 09:12 AM   #3
Battery could be culprit seen new battery die overnight. Depending on year of truck near fuse box there is a breakout for the starter. Get a test light or volt meter and have someone crank the truck while you check for power on the yellow and green wire in the little grey plug attached to the fuse now side. If you have power then ignition is good and battery or starter is bad
Redtruck-VA likes this.
