Engine Temp. - Hemi Truck Club
Old 07-01-2018, 12:47 AM   #1
F.D.Jr.'s Avatar
Engine Temp.
Question about the engine temps. I noticed the other day my 2017 running at 221 for a couple minutes but then dropped to 199. Now I know the outside temp being 95 - 100 and also running the ac will take temp up a little but 221 is that a little too high or is that normal for that temp to fluctuate that much?
F.D.Jr. is offline   Reply With Quote
Old 07-01-2018, 02:05 AM   #2
On a 3g you see the thermostat sticking closed a little on it's initial opening when first warming up. My 180 degree stat might read 195 before opening. Never 221... thats too high for my setup. For yours I don't know, but IMO it's high.
Old 07-01-2018, 06:35 AM   #3
Chrysler has been known for years woth a stock stat in hot weather to see as high as 230 degrees. It’s not uncommon and it’s not something to worry about. Once the stat opens the trucks/cars normally run around 190-210 range so as long as it does that your fine.
Old 07-01-2018, 11:35 AM   #4
F.D.Jr.'s Avatar
That's exactly what it's doing, it will go to 221 but then drop when it opens up I know thermostats open and close, and i know you have warm weather and cold weather thermostats. guess its time to put a cool thermostat inside
Old 07-01-2018, 12:08 PM   #5
Lightbulb
Summer or winter (if you really want to call it that here in Central Texas) I consistently run between 204.6 - 208.4...
Old 07-01-2018, 12:29 PM   #6
F.D.Jr.'s Avatar
So basically this T-Stat may be sticking?
Old 07-01-2018, 02:02 PM   #7
Nah it’s working fine but a 180/190 stat is better idea
Old 07-01-2018, 02:22 PM   #8
F.D.Jr.'s Avatar
I just not used to see it go up to 221. The temp gauge will not go past half so I know that is a good thing right there. always thought 212 was highest it should go.
Old 07-01-2018, 02:45 PM   #9
Agreed, 221 is too high for me. But actually as long as it isn't blowing steam it is cooling. 212 being boiling at sea level. Adding a pressure cap raises the boiling point significantly higher. And adding water wetter will make the cooling system more efficient.
Old 07-01-2018, 03:43 PM   #10
It’s normal for stock vehicles I do this all day and it’s not uncommon Chevy will reach over 230 before opening most times nothing odd there
