Drive Plate to Torque Converter bolt torque? - Hemi Truck Club
Like Tree1Likes
  • 1 Post By vvbrad09
Old 11-10-2017, 08:01 PM   #1
I have a 2011 Ram 2500 5.7 4x4 slt automatic. After I reinstalled my engine I was tightening up the 4 bolts that connect the Drive Plate to Torque Converter and the last one broke off. I was wondering if someone could tell me the proper torque for these 4 bolts and if there is a certain order or steps to use when installing. I will hopefully have the broken one out tomorrow and would really like to avoid this happening again. Thanks
vvbrad09 is offline   Reply With Quote
Old 11-11-2017, 01:49 AM   #2
What I see is 35ftlbs. with locktite. I'm pretty sure I did mine at 65ftlbs with new bolts. At such a low torque I suspect the locktite is the key factor.
Old 11-11-2017, 07:26 AM   #3
Okay thanks, what I found online was 65 for the transmission I have and 35 or 40 for the other 2 transmission models. But when I was trying to get to 65 the bolt broke and felt like that was way tighter than when I removed them. Think I will just do the 35 or 40 this time.
Old 11-11-2017, 01:39 PM   #4
The torque converter to flexplate bolts are 23 ftlbs
Old 11-15-2017, 06:32 AM   #5
Okay thanks, got them in and didn't break this time. Got everything put back together now.
Old 03-16-2018, 05:11 PM   #6
Madoyster2003's Avatar
I'm in the process of doing the same thing and for the life of me I can't figure out how to get these 4 bolts in. Is there some kind of access area? I'm about to cut the thin metal gasket thing
Old 03-16-2018, 05:23 PM   #7
FASTHEMIRAM05's Avatar
There should be a small access window per say on the drivers side of the trans
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
Old 03-16-2018, 08:05 PM   #8
That's what I was thinking however its blocked by that plate. I just yanked the trans and engine to see if that will make life easier.
Old 03-24-2018, 04:50 PM   #9
there is a bracket/plate between oil pan and trans, should be held on by like 6 bolts if i remember right. once you remove that plate just keep rotating engine to get all 4 bolts out.
ric3xrt likes this.
Tags
bolt, engine, torque, transmission
