Cylinder 7 deactivation issue. - Hemi Truck Club
Old 10-10-2016, 10:43 AM   #1
Hi all, It been awhile since I have posted but once again I have an issue. During the hurricane/storm here in Virginia I had to go out and rescue some friends. Once I got about a mile and half away from where i had to be the road was flooded out. I knew better but went on anyway and the water got too deep to stop or back out but I pushed threw and of course started getting all the warning lights. However I completed my mission and returned home but hurt my Durango in the process. I limped home and just put it into the garage. Later on broke out my scan tool and started to check some things. I keep getting a p1417 cylinder 7 misfire/deactivation code. The engine still has a pretty smooth at idle but shacks like crazy once you try and drive it even if you go into the tow mode to cut out the MDS. Today I cleared the codes, disconnected the battery, and did the hard PCM re-set. Seems little better but still have a miss and shake. Engine never stalled during the drive so I don't think water into the cylinder was a issue, all fluids are still the right colors. I changed this engine out about 2 years ago after my daughters killed it and really don't want to relive that again. i'm thinking this is more electrical than mechanical so any help would be welcome....
vmanmopar is offline   Reply With Quote
Old 10-10-2016, 12:54 PM   #2
My first guess is you got water in one of your electric connectors, but since its point at one cylinder I'd start by doing a compression check. You might even find water down around the spark plug boots.
Old 10-11-2016, 04:33 AM   #3
Yes check for water intrusion first on cylinder 7. Then move the coil and while there do a compression check to make sure cylinder is ok.
Old 10-20-2016, 05:25 PM   #4
Hi all, Im finally getting around to posting an update on the durango. Well she runs, I started with checking the connectors, unplugging and plugging them back together. This kept reducing the amount of codes I was seeing until I was just down to the cylinder 7 mis-fire code. I removed the plugs and they were fuel wet, but ok no carbon or bad gaping. Anyway I also had read about valve spring breakage so since I had the coil packs off already I removed the drivers side valve cover for a peak. Was not as hard as I thought it would be to do. Everything under the cover looked good and in the right places. I buttoned it back up and being late I put number 7 plugs into cylinder 1 and also swapped the coli packs around to see if the miss would travel. Started it up and it was smoother still and I cleared all the codes but it still was missing through the exhaust. Now I was getting just the random misfire code instead of a numbered cylinder. i
I also had read about some intake leaks and about cowl water leakage. No leaks on the intake. I did change the mass air sender with one from my truck and restarted the engine it was little rough at first and then she finially smoothed out. cool! its fixed! I had a feeling that this was more electrical PFM than mechanical. I washed the durango and took it for another ride and was still ok. I opened the hood to check on this leak thing and sure enough I could see water dripping right down onto the throttle body and cylinder 7. Anyway the wife took the Durango and of course 7 miles from the house it started acting up again. I got it home and was playing with the number 7 fuel injector connector and that is what my problem is. The connector is not sealing and the water is getting into it causing the misfire. I don't know if my water forging drive or the rain or just timing but so far so good. I understand there is a upgraded cowl and seal for these years so i'm going to look into that in the mean time I sealed the push lock (christmas tree) with some RTV and i don't see anymore water leaking onto the engine. hope this may help someone else out.
Good thing for the edit button
Old 10-20-2016, 05:32 PM   #5
Nicely done....
Old 10-20-2016, 06:03 PM   #6
good thing for the edit button, I should not be typing and drinking gentleman Jack at the same time...LoL
Old 10-21-2016, 03:13 AM   #7
I use dielectric grease on connections which helps to keep moisture out of them.
Old 10-22-2016, 06:22 PM   #8
in addition to everything i did use the dielectric grease also. Learned about that grease when repairing my NSS (Neutral safety switch)on my jeep Cherokee.
Thanks so far running good....
Old 10-22-2016, 07:00 PM   #9
Cool deal!
Old 10-23-2016, 05:58 AM   #10
Gold-Member
kcd1369's Avatar
