Cooling the hemi - Hemi Truck Club
Old 07-22-2016, 09:56 AM   #1
Cooling the hemi
I've noticed as horsepower has increased so has the water temperature. Using a 180 thermostat and a new 05 radiator. This is not unexpected, but was wondering what radiator setup is being used by the high output guys. Is there a bolt in replacement or is a custom built radiator needed? The temperature use to be 188 cruising on the highway and in town with stop and go stuck in traffic I could see 203 when the fan comes on and pulls it back to 194. Now I see temperature creep with most any load on the engine even at cruising speeds. So what's the cool setup?
Old 07-22-2016, 10:13 AM   #2
Lightbulb
Do you run an extra capacity - oversize oil cooler too?
Old 07-22-2016, 10:33 AM   #3
If you are talking about engine oil cooler, no. The only addition to the front is the intercooler radiator. The stock radiator, then trans cooler and finally the intercooler radiator. It's a pretty busy area.
Old 07-22-2016, 10:44 AM   #4
Exclamation
Yep no doubt space is at a premium with your set-up . You may have to go the custom-built route with an extra thick core cross flow radiator if space permits .
Old 07-22-2016, 11:18 AM   #5
I use a fan behind the intercooler heat exchanger. It also blows air on the trans cooler. Along with a Black Magic (300cfm) electric fan, 180 thermostat, doesn't go above 185 degrees even on a hot day.
NOTE: Drilled the vent hole a little bigger at the top of the thermostat. The hole will also vent air out of the engine when refilling the cooling system. You know how it's a pain to get all the air out of the engine cooling system with the stock thermostat....
That reminds me, have to get a better radiator overflow tank.
Old 07-22-2016, 11:33 AM   #6
Stu, what radiator are you using? Maybe all I need is a fan on the front of the stack of radiators blowing more air??
Old 07-22-2016, 11:47 AM   #7
Advanced Auto 05 Hemi Ram radiator. You just probably need a fan Greg.
Old 07-22-2016, 12:25 PM   #8
Mine sometimes will run warmer than normal. Wondering if it's something with my radiator. It's the stock one with 113,250 miles on it so wondering if I should try changing it out. Like I said sometimes it will just run warmer than I'm comfortable with but not always
Old 07-22-2016, 01:15 PM   #9
It'd be cheaper to try a fan then pop for custom radiator. They run around a $1000... ugh
Old 07-22-2016, 02:39 PM   #10
Matt
MANual_puller's Avatar
Fwiw the radiator in my '11 is giant compared to what the '06 had. I have the optional larger one, I forget exactly what they called it on the window sticker, I'll check later. The radiator and a/c aren't side by side in the '11
EDIT: There is no optional larger radiator. It's standard as "heavy duty engine cooling". The 4th gens use a different radiator for 2500 trucks where the 3rd gens used the same radiator for both half and ton. Learned something new today
