condenser fan motor - Hemi Truck Club
Old 07-24-2016, 01:31 AM   #1
08blueram's Avatar
condenser fan motor
Question is anyone having the fan motor go out often? The ones from advance and autozone last 6 months for me I bought the one from dodge it lasted 2 years but went again and at 300+ I don't wanna do that again. Anyone have any ideas thanks
08blueram is offline   Reply With Quote
Old 07-24-2016, 02:33 AM   #2
No doubt you use your AC a lot. But still I feel that is way to often to burn out. I would check the ground and power going to it. But personally I would find out its current draw and connect an adequate size relay to it with power coming from the battery, with it's own ground. Thiis is how I have my efan wired and its been running in this configuration for years without issues. Then look for a fan motor with a lifetime warranty , maybe Rockauto would give a good selection of motors?
Old 07-24-2016, 02:45 AM   #3
08blueram's Avatar
I will check that out I just get tired of replacing it lol.
Old 07-24-2016, 05:29 AM   #4
at work I have changed a lot of them but not on the same truck. make sure your ac charge is full also so the fan doesn't cycle on and off if the compressor does. dodge truck run the fan as long as the compressor is running if it cycles they shut it off and start it back up. the ground for the fan is 1 of the two grounds of the drivers fender lip edge there near the fuse box or up by the cowl. your truck has a timp so there is no relay to change.
