Change your oil. - Hemi Truck Club
Like Tree3Likes
  • 1 Post By Davidk
  • 1 Post By Redtruck-VA
Old 06-21-2019, 03:48 PM   #1
Davidk's Avatar
Change your oil.
Most dont know. If your oil psi drops below 31 and stays below the engine timing is kicked out and the computer won't advance or retard the timing. This produces pinging , poor performance , and just run ability issues in general as well as internal damage. These engines are already known for lifter failure . Dont accelerate the issue . Just a heads up
kcd1369 likes this.
Davidk is offline   Reply With Quote
Old 06-21-2019, 05:55 PM   #2
David, you are right I haven't read that anywhere. What is your reference for this information?
Old 06-21-2019, 08:52 PM   #3
I found this in a service manual. Looks to me that 25 psi oil pressure is considered normal as the low side.
DIAGNOSIS AND TESTING - CHECKING ENGINE OIL PRESSURE
1. Remove oil pressure sending unit and install gauge assembly C-3292.
2. Run engine until thermostat opens.
3. Oil Pressure:
Curb Idle– 4 psi minimum
3000 rpm– 25 - 110 psi
4. If oil pressure is 0 at idle, shut off engine. Check for low oil level, a clogged oil pick-up screen, or a pressure relief valve stuck open.
Old 06-21-2019, 09:05 PM   #4
Yes hemi engines have very low idle pressure but soon as it’s reeved up it shots right back to spec.
Old 06-21-2019, 09:24 PM   #5
Anything under 35psi bothers the hell out of me..
HemiFun05 likes this.
Old 06-22-2019, 12:39 PM   #6
I run AMSOIL 5W30XL Synthetic engine oil in my 2007 Quad Cab 1500, rwd, 5.7L Hemi. My oil pressure at operating temp. has always been the same.
2019 OUTSIDE TEMP. 95 DEGREES
700 RPM: 35 PSI
1,500 RPM: 55 PSI
Old 06-22-2019, 12:41 PM   #7
Davidk's Avatar
P1524. Oil pressure out of range . Cam timing advance / retard disabled
Old 06-22-2019, 01:01 PM   #8
To clarify you are speaking of VCT, not ignition timing...
