CAn I get some info for an upcoming control arm job. - Hemi Truck Club
Like Tree2Likes
  • 1 Post By fast69mopar
  • 1 Post By charged392
Old 08-30-2019, 01:35 PM   #1
I
I am going to be replacing my driver side control arm on 2003 1500. I was wondering if anyone knows the socket sizes I will need, and the torque specs.
I would like to get a half inch driver set, but I don't really have the money for it. So if I knew about what range of sockets to get to help minimize the cost.
I is offline   Reply With Quote
Old 08-31-2019, 01:13 AM   #2
fast69mopar's Avatar
You can pick up a cheap set of 1/2" sockets from Harbor Freight. I picked up a cheap set to beat on for like $12.99 last week.
The tie rod ends are 21mm.
The upper and lower ball joint nuts are 22mm or 7/8"
If 4WD the axle nut is 35mm
The caliper bolts are 21mm
Torque the 22mm upper ball join nut to 40 foot-pounds plus an additional 90 degrees
Torque the 22mm lower ball join nut to 38 foot-pounds plus an additional 90 degrees
Torque the tie rod nut to 45 foot-pounds
Torque the caliper bolts to 130 foot-pounds
Torque the axle nut to 185 foot-pounds (4WD only)
Torque the lug nuts to 135 foot-pounds
arocketman likes this.
fast69mopar is offline   Reply With Quote
Old 08-31-2019, 10:44 AM   #3
I
Thanks for the info. Would you happen to have the control bushing bolt, and there torque specs?
Old 08-31-2019, 09:57 PM   #4
Torque the upper ball joint not to 135 foot-pounds.
Torque the control arm attaching bolts to
120 foot-pounds.
My '04 gets down!
Old 09-01-2019, 03:37 PM   #5
Here is the chart you need
File Type: jpg 566C1DB6-5FB2-498E-9444-6B9B3FE2109D.jpg (59.0 KB, 12 views)
