Ball Joints - Hemi Truck Club
Old 10-27-2016, 03:20 PM   #1
HemiDave's Avatar
Ball Joints
Looking to replace my ball joints and tie rod ends but have never done a ball joint replacement. Looks pretty straight forward though.
My question I guess is more around the joints and brands. I see some, Carlis, that are rebuildable but also about $600. I have seen others that are more OEM and not rebuildable. Have read a lot about Moog going down hill and should consider them anymore.
Thoughts and advice on this one?
'03 2500 SLT 4X4 HEMI Ram
Drop-In K&N Filter
Line-X Bedliner
PIAA Ultra White Headlights & Silverstar Fog Lights
Westin Chrome Step Bars
Mostly Stock and Still Runs Like a Champ!
HemiDave is offline   Reply With Quote
Old 10-27-2016, 04:26 PM   #2
I replaced the ball joints last year on my 03. I went to Rockauto and choose the ones I wanted. They list several with a range of prices.
Old 10-27-2016, 11:44 PM   #3
HemiDave's Avatar
Thanks for the tip.
How was the overall job??
Drop-In K&N Filter
Line-X Bedliner
Old 10-28-2016, 04:12 PM   #4
Ball joints are not hard at all with the press and a good impact gun. For the lowers I use a big hammer is all to remove come rite out normally.
Old 10-29-2016, 09:45 AM   #5
HemiDave's Avatar
Rock on...thanks man.
Looks like Moog has a pretty good set. Might go that route.
Drop-In K&N Filter
Line-X Bedliner
Old 10-30-2016, 07:12 AM   #6
Old 10-31-2016, 11:08 AM   #7
Andler2008's Avatar
Also, throw some anti seize on the threads and the taper. That way if you're the rust belt, you won't have as much of a headache pulling them off. Or, if you use cheap ones that need replaced in 10k miles, then it'll still be super easy to disassemble.
Ohio winters are hell on my cars. and I keep them garaged and usually clean the under carriage if it was an exceptionally dirty week or terribly salty.
2006 Dodge Ram 1500 Big Horn Edition
5.7 Hemi (Stock)
5100 Bilsteins on lowest adjustable setting
2" Shackle Drop
20"x12" Vision Rage Wheels
Nitto NT420 305/50/20 Tires
Debadged, Tinted Windows, and LED spotlights added to the Hitch.
Andler2008 is offline   Reply With Quote
Old 10-31-2016, 05:14 PM   #8
TooCool's Avatar
I replaced my lower ball joint's with these. They seemed good quality and are greaseable. (IIRC the engineer that designed them use to work for Moog.) Give them a look at. Sorry for the late post I haven't been able to post and kept getting the 3 character thing.
XRF Chassis | Automotive and Heavy Duty Chassis Parts | What Makes XRF Better
Old 11-11-2016, 07:10 PM   #9
HemiDave's Avatar
Thanks all for the input...just ended up going all Moog. So many mixed reviews but more on the positive side.
Drop-In K&N Filter
Line-X Bedliner
Old 01-24-2017, 04:52 PM   #10
crash83's Avatar
So how bad was it to change them out?
crash83 is offline   Reply With Quote
