Alternator running high - Hemi Truck Club
Old 02-02-2017, 03:18 PM   #1
327
So, ive had this issue for a while.
The last alt literally died completely. But before it did (when it worked) the gauge on the dash would read a little on the high side. I cant say how long it has been like this, because the old lady mainly drives this truck.
Anyways, got a new alt on now, and it is the same way.
Why might my amp gauge be running higher than normal.
327 is offline   Reply With Quote
Old 02-02-2017, 06:42 PM   #2
That's obviously a problem, I would check the grounds and connections. And the battery can often have odd symptoms. The regulator is within the pcm.
Old 02-02-2017, 08:14 PM   #3
What I said the actual charging voltage at idle loads off and 2500 rpm loads off then same deal loads on?
Old 02-04-2017, 09:02 AM   #4
327
Say what now?
The neg batt cable looks to may have some corrosion in it. I'll check resistance there.
1 of the battery cells looks like it could be starting to get ill.
Batt voltage is 12.4.
Old 02-04-2017, 09:18 AM   #5
Exclamation
Seems just a tad low for the fully charged standing voltage...check under full load .
Old 02-04-2017, 04:55 PM   #6
That's about normal sitting voltage 12.4-12.6 range is fine running should be around 13.3-14.5
Old 02-04-2017, 05:07 PM   #7
327
Running is 14.4v.
Picked up a new batt today. Gonna toss it in tomorrow and see.
Old 02-04-2017, 05:18 PM   #8
That's not to high that's about normal for some. How cold is it war you also is that loads on or off?
Old 02-07-2017, 05:16 PM   #9
Shifterbrains's Avatar
That's pretty close to where mine has been running.
Old 03-23-2017, 06:22 PM   #10
327
Looks like deep corrosion in Pos battery cable causing high reading.
