2009 - P0430 code - Hemi Truck Club
Old 08-19-2016, 11:24 AM   #1
Edmonton's Avatar
2009 - P0430 code
I just recently got this code, did some research and it's a pretty wide range of possible issues.
170k on the truck .. just bought it so I'm not sure of when anything may have been replaced as far as O2 sensors and plugs
I have however been told EGR valve could be the cause, problem is I've looked where it should be or has been on previous years but I don't see anything similar? Does the 09 have this sensor and is it the best place to start?
Thanks
Edmonton is offline   Reply With Quote
Old 08-19-2016, 11:26 AM   #2
hemiram13's Avatar
You need a cat on bank 2.
2013 RC Express HEMI
Old 08-19-2016, 11:29 AM   #3
Edmonton's Avatar
Brutal, I was hoping that wasn't the answer but it is what it is
Thanks Hemi
Old 08-19-2016, 01:55 PM   #4
You can swap the 02 sensors on the 2009 truck I believe side to side all of them and see if the code moves. The 430 means the catt is basically not removing the unburned fuel and the downstream O2 is picking it up as a catt issue or the O2 is bad downstream and setting the code. 9/10 times the catt is the issue though and when we do them we suggest all new sensors also so the new Catt has the best readings and lifespan it can get.
Old 08-19-2016, 03:12 PM   #5
Edmonton's Avatar
If I leave the cat .. can I expect anything worse? ... There is no emission test in Alberta .... *Home of the jacked up oil riggers*
Old 08-19-2016, 03:19 PM   #6
Tyler
TYSENUS's Avatar
*Used to be home of the jacked up oil riggers*, till they voted in the NDP...
Mods:
Old 08-19-2016, 03:22 PM   #7
Edmonton's Avatar
Lmao so true
Old 08-19-2016, 03:39 PM   #8
If it's bad it may plug up soon and then the tuck won't be mobile!
