2003 3/4 ton QC SB 4x4 hemi....time for rebuild - Hemi Truck Club
Old 10-21-2017, 09:12 AM   #1
pri_i_oh's Avatar
So for those that are following my other post, I decided to move it to this thread because it's officially turned into a rebuild.
I decided that since it has over 200k miles and I was obviously going to have to do some internal repairs I may as well pull the motor and freshen it up a bit. I plan on working this truck pretty good so I figured I may as well do the work now and have a more reliable engine for the future. Right now I'm working on getting the crank pulley off. So far, I've bent 2 pullers....lol...time for some new ones. These ones have been used and abused for many years
Old 10-21-2017, 09:21 AM   #2
ric3xrt's Avatar
PB Rust buster, pull the crank bolt and spray a ton of it in there come back 3 days later and it should come off easier.
I had a 6.1 Charger that was a flood car, that whole thing was a mess to pull apart. but the crank pulley took out my new at the time "Hemi/ls damper pulley.
Old 10-21-2017, 10:56 AM   #3
pri_i_oh's Avatar
Well, there's a new style puller for these that's a lot more stout. I'm gonna have to go get one today or tomorrow
Old 11-01-2017, 03:39 PM   #4
pri_i_oh's Avatar
Ok guys, I'm looking for input and opinions from the professionals....thats you guys...lol. This is kind of a budget build but I don't want to go too "cheap" and have to do this again in 2 years. Obviously I'm gonna replace the timing chain and gears, rod and crank bearings, rings, gaskets and typical tune up parts. I'm also gonna replace the O rings on the injectors. All the coils look like crap so I think I'm gonna get one of the kits from summit that has all 8 because they seem like a pretty decent price. Anyone have any experience with those? I think a new oil pump is a good idea. I'm thinking just a stock replacement unless anyone sees a huge reason to go otherwise.
The 2 biggies I'm on the fence with are the water pump and wires.
As far as the water pump goes I've heard a lot that it should be a factory replacement and not to go with aftermarket because of tolerances.
As far as wires go, a buddy of mine got a "shorty" wireset from summit that really cleans it up pretty nice and from what i understand its actually a better quality set of wires......thoughts??
Old 11-01-2017, 06:07 PM   #5
If you don't have the experience with rebuilding engines. I would suggest a re-manufactured long block. It's the easy way to go.
Old 11-01-2017, 06:14 PM   #6
pri_i_oh's Avatar
I've rebuilt engines before and it's not even my first hemi. I'm just looking at options that's all. I know what I've done in the past and what's worked and what didn't. Like I said, I'm just deciding on a few options that's all
Old 11-01-2017, 06:16 PM   #7
Old 11-01-2017, 10:43 PM   #8
pri_i_oh's Avatar
After researching the shorty wires it sounds like a lot of people are having hard start issues, random miss fires and less mpg. I was under the understanding that the 06 hemi went to this as a factory set up. It definitely looks cleaner but I'm assuming there must be been a change in the coils too with the 06 and up in order for them not to have those same issues?
Old 11-02-2017, 07:25 AM   #9
Enormous Member
Hugh Jassole's Avatar
using shorties with no issues here
My other truck is an R/T
Old 11-02-2017, 08:58 AM   #10
oldmanram's Avatar
Are you planning on HONING it (rering) or BORING it (new pistons) ?
