01-07-2021, 06:38 PM
#1
Randall
PCM repair
Anyone got a good recommendation on PCM repair or had one repaired? Bought an 05 Ram manual trans PCM from a member here in the forum a few years back and finally got around to installing it. With my luck it has some sort of issue. It’s not sending the proper signal for the injectors. It basically just floods the cylinders with gas. My tuner traced it back to the PCM. When we put the Automatic PCM back it everything works as it should with the fuel system. Anyone who knows PCM’s knows this is a Unicorn and very rare and hard to find. Thanks in advance
Procharged P1Sc, Big valve P&P heads,HC lifters,Inertia Blower cam, Mopar long tubes with SS 3"true duals, Magnaflow hi-flow cats & Race mufflers, T56 manual swap with Centerforce DYAD clutch, Dana 60 with cryoed 4.56 gears, Caltracs, Flexalite & custom Injected Engineering dyno tune.
