Hptuners Tire Diameter - Hemi Truck Club
Go Back   Hemi Truck Club > HEMI | Performance Zone > Chips, Tuners and Programmers
Like Tree8Likes
Old 01-06-2020, 03:55 PM   #1
Tom
Apparently the HPTuners doesn't support tire diameter on 04 and down. What are my least expensive options for adjusting that? Superchips is coming in at 199, is that my best bet? I can't find an 05 PCM locally to save my life, this thing has me banging my head against the wall some days.
2004 QCSB 1500 4X4
triplethreat is offline   Reply With Quote
Old 01-06-2020, 07:02 PM   #2
That or an old diablo predator but not sure if it will 100% work or not as the older trucks have been known to have issue related to tire size and abs light issues
bada44 and Redtruck-VA like this.
Old 01-06-2020, 07:55 PM   #3
Tom
Thats my luck. The machine shop that did the valvejob, screwed that up, I have a leaking exhaust valve, and this now, still makes me want to put the engine in my 72 crew cab with the dual quad intake and be done with this thing.
ric3xrt likes this.
2004 QCSB 1500 4X4
Old 01-06-2020, 10:58 PM   #4
IMO, swaping the pcm is the best way to go...
Old 01-07-2020, 06:55 AM   #5
Have you read through this thread?
https://forum.hptuners.com/showthrea...ent-size-tires
Old 01-07-2020, 10:14 AM   #6
Tom
My scanner doesn't give the option to do anything related to gears or tires. The green button opens a blank window. There isn't anything in the editor either.
2004 QCSB 1500 4X4
Old 01-07-2020, 10:31 AM   #7
You might look at downloading the latest version. They upgrade often..
Old 01-07-2020, 07:07 PM   #8
Tom
I've updated up until last week, haven't messed with it much since then. But then I've been using the beta, I haven't used the retail version in a month or two. Probably wouldn't hurt to try that one to see if there are any differences.
2004 QCSB 1500 4X4
Old 01-07-2020, 09:45 PM   #9
My truck had the abs light pop on when I just played with the pcm swap flash truck deal to get logans truck running. Used my scanner to reset the pinion factor back to stock and it went away.
Old 01-07-2020, 09:57 PM   #10
Tom
Fromm everything I have read, the 04 and down, don't have any support for accessing anything related to the speedometer aside from torque reduction and speed limiter. I am going to have to move to the 05 PCM to be able to do anything. Are there any reputable places online to order a PCM? They just don't exist around here.
2004 QCSB 1500 4X4
