HP Tuners VCM Suite - Page 9 - Hemi Truck Club
Go Back   Hemi Truck Club > HEMI | Performance Zone > Chips, Tuners and Programmers
Like Tree73Likes
Old 06-03-2019, 02:58 AM   #81
How much are the credits?
Old 06-03-2019, 05:31 AM   #82
Mark G Senior Member
bada44's Avatar
credits are $50 per and it takes 2 for our trucks.
kcd1369 likes this.
Please Donate today!
https://www.stbaldricks.org
I stand for the flag!
[email protected]
bada44 is online now   Reply With Quote
Old 06-03-2019, 10:32 AM   #83
xtremwlr's Avatar
Originally Posted by 04sthemi View Post
Originally 2, I know my pcm setup isn’t like the 03s where when talking to you a while back I “should” be able to just swap in a 05 pcm.
My 04 has a build date of 9/2003. I had zero issues when I swapped in the 2005 PCM. It's still in the truck today and it run better than ever. You shouldn't have any problems.
Old 06-09-2019, 08:31 PM   #84
Been modifying the timing tables to where there is no chance to exceed 22 degrees total. Then changes the timing down around idle area. Basically I raised timing below the rpm idle target and turned down the timing a touch above the target idle rpm. It idles at 750rpm solid as a stocker and this is with a stout cam with
.611" lift.. changed the throttle threshold voltage which smoothed out the light switch effect. There are tables that are enabled at various ect, map iat levels. Also tables that are blended. My goal currently is to make everything as simple as I can to have basic control. I need to connect my w/band to help with fuel settings. This is easy and honestly a lot of fun... but some care needs to be taken and a backup plan in place.
Old 06-10-2019, 04:27 PM   #85
Gold-Member
kcd1369's Avatar
Old 06-20-2019, 09:35 AM   #86
Seems like it could get expensive quick? Is it a $100 a tune? Or, is that just to get started?
Old 06-20-2019, 01:19 PM   #87
xtremwlr's Avatar
The way I am reading it, it's $100 to register the vehicle and then you can tune to your hearts desire. Similar to using a diablo, register for your truck and then you can tune as much as you want.
Old 06-20-2019, 02:36 PM   #88
It’s a one time fee or a one way ticket to a blown motor if you have no clue what your doing
Redtruck-VA likes this.
Old 06-20-2019, 06:52 PM   #89
bada44's Avatar
2 credits per vin you tune forever.......
[email protected]
Old 06-21-2019, 09:20 AM   #90
If you have a vehicle licensed and change it's pcm, you will need to relicense it.
kcd1369 likes this.
