O2 Sim Install - Hemi Truck Club
Old 03-21-2010, 06:53 PM   #1
Heywood's Avatar
O2 Sim Install
Got my O2 sim installed and it's for real. I take my time with wiring projects to get them right and make them look clean so it probably took longer than most. I will say that finding the right wires was a pita. This attached may help future installers as their instructions are generic. The way mfgr's hide all the wiring nowadays it was difficult to find a keyed +12v. I stared at the fuse box for a while trying to figure out how to tap into an unused slot but it was more work than it was worth.
Heywood is offline   Reply With Quote
Old 03-21-2010, 07:04 PM   #2
O2 Sim Install
Good info! Thanks for sharing this with our members
Old 03-21-2010, 08:12 PM   #3
O2 Sim Install
i'm curious to see if this is a permanent solution, i was told by someone who makes the 02 sims for older dodges that newer dodges, especially the hemi, will throw a code after it realizes that the 02 sim is there. the pcm knows that the sim is there because it shows a constant voltage is what i heard. the 02 sensors in the newer vehicles go through a test sequence and e sims don't allow that test to happen. so after a while, from what i was told, the CEL will be on.
bighemitex is offline   Reply With Quote
Old 03-22-2010, 10:39 AM   #4
Heywood's Avatar
O2 Sim Install
Watching the sim thru diag software it does not show constant voltage and IIRC varies w/ throttle response. It does however show Closed Loop Mode first thing when starting up cold, so it never enters Open loop until warmed up.
Old 03-26-2010, 09:08 AM   #5
Heywood's Avatar
O2 Sim Install
Well this last week I threw another P0430 code, which I thought was pretty impossible with the O2 sim installed. So far they've only returned 1 email and it was pretty thin. We'll see.
Old 03-26-2010, 09:24 AM   #6
O2 Sim Install
i guess this confirms what i heard. electrical sims won't work in a hemi. only mechanical sims or custom tunes for us
Old 03-26-2010, 11:55 AM   #7
Heywood's Avatar
O2 Sim Install
I'm still holding out hope they can resolve this.
Old 03-26-2010, 12:07 PM   #8
O2 Sim Install
i heard from a reliable source it's not possible. i investigated this option a while back because i was worried when i do my header install i will get a CEL and all my research said these electric sims won't work on a newer pcm. they don't allow the OBD2 test to work on either pre start up or post start up(i can't remember which one it was)
Old 03-26-2010, 01:28 PM   #9
HemiCane's Avatar
O2 Sim Install
I've had mechanical sims for a couple years now and don't have any problems.
HemiCane is offline   Reply With Quote
Old 03-26-2010, 05:53 PM   #10
Heywood's Avatar
O2 Sim Install
quote:I've had mechanical sims for a couple years now and don't have any problems.
By mechanical, you're using the anti foulers w/ steel wool?
