Every exhaust clam leaks - Hemi Truck Club
Like Tree2Likes
Old 09-30-2018, 03:51 PM   #1
SnakeJr's Avatar
Sup yall. I just posted a pic of my split muffler. When I was under there I realized every clamp I just put on is leaking. I used clamps they supplied in the kit. They're all lap joint clamps and each on leaks. Any ideas? I tried moving them and tightening them again. I just cant seem to figure this out. Maybe need a new style clamp. Pictures to follow shortly
SnakeJr is offline   Reply With Quote
Old 09-30-2018, 06:13 PM   #2
I use a combination of these https://www.summitracing.com/parts/sum-692030
And V band clamps...
Old 09-30-2018, 06:20 PM   #3
SnakeJr's Avatar
The pipes I have fit into on another. I dont think those clamps would work.
Old 09-30-2018, 07:48 PM   #4
Chris
YeahItsAHemi's Avatar
I use some of those band clamps and they all leak. I’ll be welding v bands on real soon
Tuned by Charged392
Tons of Pics https://www.flickr.com/photos/1594207[email protected]/albums
Old 09-30-2018, 07:48 PM   #5
TylerB's Avatar
Clamps suck... Only thing you can do with them is put the ultra copper exhaust gasket maker RTV in the joint, switch over to v-band joints, or have every joint welded.
TylerB is offline   Reply With Quote
Old 09-30-2018, 08:11 PM   #6
Clean welds with nice beads, check and check again
Old 09-30-2018, 08:13 PM   #7
SnakeJr's Avatar
I was afraid that was the answer. I like the idea of clamps but they all suck. It's not so bad when everything warms up but that cold start
Old 09-30-2018, 08:17 PM   #8
Gold-Member
kcd1369's Avatar
That stinks. Good luck.
Old 09-30-2018, 08:28 PM   #9
I have the stainless steel band clamps on 3" pipe that don't leak. I cut 4 slots in the outer pipe that allows it to compress when the band tightens. I use a pipe expander to make the pipe fit properly and take care when assembled. The vband are superior IMO and will change over to them in the future.
Old 09-30-2018, 08:30 PM   #10
SnakeJr's Avatar
Damn good idea. That's easy enough as well
