Best options for an '03 - Hemi Truck Club
Old 07-31-2014, 11:11 AM   #1
Tom
BadassBlues's Avatar
This is the one area that is as clear as mud to me, exhaust.
I have read that the '03 Hemi (and others) require a certain back pressure to run right. This makes it difficult to determine the optimal exhaust system as I am mechanicaly inclined, but technicaly ignorant. I have no means to test the system I decide on and am relying on an experienced opinion.
What I want is performance, not noise. I like the nice low rumble of a good muffler, but I don't have any desire for race track decibles.
What would be the best option? I have heard opinions on true duals, but what about the back flow issue? I have read about the Magnaflow Y pipe opening it up, but what then? The O2 sensor on an "03 is located at the Cat, so changing to a high flow catalytic converter could create problems in the emission system and I HATE seeing the check engine light glaring at me.
The best option I have heard (to my limited knowledge) is to leave the factory exhaust manifolds and Cat and install a decent muffler with two side outs. Would that do any good at all for performance or just be a cosmetic mod that makes it sound better?
I am really confused on this issue and hope someone has an answer.
Thanks!
BadassBlues is offline   Reply With Quote
Old 07-31-2014, 12:23 PM   #2
This is what I have done on my 03 RCSB and am very happy with the results. Pacesetter Long Tube (Ceramic coating), ORY pipe, Two Magnaflow spun cats and the 36" long round Magnaflow SS 3" in/ dual 2-1/2" out with pipes out the rear. The spun cats are something like 10" long, cut that length off the ORY pipe and weld the cats back to the ORY pipe to make up the length removed. This will locate the cats pretty much over the cross member. Add a O2s bung on the cross over pipe. Each collector has a bung, screw in the forward O2s into the passenger side collector. The new bung on the cross over pipe will be the rear O2s. The spare bung on the driver side collector is ideal for mounting a wide band sensor. Simple and sweet.
Good luck..
Old 07-31-2014, 12:32 PM   #3
I would say any exhaust you do headers or not run a y pipe to a single in single out or dual out. As for muffler the magnaflow ss is decently quiet for sure. Any muffler 16" or more with padding inside will likely be quiet enough also.
Old 07-31-2014, 01:58 PM   #4
Tom
Good luck..
Looks like a nice set up. What have you noticed for gains? Also, how loud is it with the headers?
I have been concerned about putting headers on because of the volume and also because I had an exhaust guy tell me they require a lot of maintenance keeping them tight to the engine. Have you noticed any trouble with them coming loose? What is the benefit of the ceramic coating?
Have you noticed any loss of low speed, around town performance?
Old 07-31-2014, 02:03 PM   #5
Tom
Thanks for the advice. I like that low rumble of a well tuned V8 with a good performance muffler, but I hate the excessive volume and the backfire of really aggressive exhaust systems for daily driving.
Old 07-31-2014, 02:19 PM   #6
This is what I have and in my book solid gold for sound. I get compliments practically every time I go out.
http://www.summitracing.com/parts/mpe-12762/overview/
Old 07-31-2014, 05:44 PM   #7
Gold-Member
kcd1369's Avatar
Good luck..
Greg,
I have thought of doing my O2's and a wide band setup like this. But, my concern is will the PCM and Wide Band be getting a true read on the engine performance having each sensor registering only 1 side of the engine each.
Has this ever been a concern of yours? I know you pay more attention to Red then most average drivers do. So you are very in tune to your performance. But do you think it would be OK for the average Joe?
Old 07-31-2014, 06:18 PM   #8
Originally Posted by kcd1369 View Post
Greg,
I did have concerns if it would read correctly and I've seen some other 03's use this configuration without issue. I did a lot of spark plug reading and monitored my knock sensors and found no problems. When I was using the Megasquirt I also read from one side only and again found no issues. I'm still aware of it reading one side when diagnosing a problem but not concerned it represents a problem doing so. IMO, anyone running LT's and custom exhaust isn't a average Joe and is more atuned to the querks of their vehicle than most. With that said there isn't an alternative if dual cats are used on a 03 with a single O2s reading exhaust. Plus the RCSB trucks really don't have enough room under them to use a single cat behind the ORY pipe even if someone wanted to. I'm afraid it is what it is...
Old 07-31-2014, 06:19 PM   #9
Hemi-fied 03's Avatar
I've got an 03 regular cab with short bed. I installed Edelbrock shorty headers with a Summit brand exhaust....single 3" inlet and dual 2.5" outlets. Have had this set up for a while. Has a low rumble unless you really get in it....not obnoxiously loud. To keep the headers tight, I installed Stage 8 bolts. I put them on, tightened them, and forgot about them. Like I said, it's been this while for several years, and I have had no issues. Everything was bought from Summit, if that helps.
Hemi-fied 03 is offline   Reply With Quote
Old 07-31-2014, 06:28 PM   #10
Tom
That helps a lot, thank you.
