2011 Ram with 14" Magnaflow - Hemi Truck Club
Old 12-10-2011, 05:25 PM   #1
Dreamin' HEMI's Avatar
So here it is....pumped up that my muffler is to be installed this morning. Anticipation building up all week for this "event". Arrived at muffler shop early. Tech took it in and up on the lift it went. 15 minutes later shop foreman says he can't install, at least on a weekend...this is going to take longer than he thought. Since the spacing on the Magnaflow is narrower on the exit side when compared to the stock exhaust, and since the stock is tilted (for spacing?) he needs to build to the factory dual pipes if I want to keep them. Oh well, left disappointed and still with my factory exhaust on with the stainless steel Magnaflow still sitting beside me. Dropping it of Monday morning to be finished when I get off work.
2011 Hemi Sport Crew Cab - Magnaflow exhaust, CIA, Plasmaglow Firestorm
2003 Ram 1500 HEMI SLT / 6" BDS Suspension Lift / 35x13.50 R20 Dick Cepek Tires / 20x10 Helo Maxx 6 Chrome Rims / Superchips / Flowmaster "Hemi" Muffler / "Home-Brew" CAI / 1500 Watt RMS Kicker Stereo System / 2 12" Subs Under Back Seat / Sirus Satellite Radio / Stainless Steel Grill / Added Cab Clearance Lights / In-Grill Driving Lights / Tailgate Torsion Bar / Bushwacker Fender Flares / 4.56 Motive Gears / Royal Purple Fluids / Taylor "Shortie" plug wires / 180 T-stat / Chrome gauge bezel / LED Tail Lights & Third Brake Light / Fire & Ice Bar
Dreamin' HEMI is offline   Reply With Quote
Old 12-10-2011, 05:25 PM   #2
Old 12-10-2011, 07:38 PM   #3
Farrrrrr East Coast
NewfieBullet's Avatar
mine went on fine, stuck the factory tailpipes in the magnaflow and used about 14" of 3 pipe straight...didnt have to bend anything just swell the factory tailpipes to fit the magnaflow
Old 12-11-2011, 02:09 AM   #4
Mr. Freeze
VA4MEDS's Avatar
All he has to do is weld a strap on the pipes right after the muffler to keep them aligned.
Sounds like he is making a small job into a project.
Old 12-11-2011, 02:50 AM   #5
He says it's due to the twisted mounting of the factory pipes that's the problem. Said it would make the exhaust tips way out of alignment since he would have to bring them in together more at the muffler. Did your factory muffler sit flat or was it held at about 45 degrees mounted at an angle? Perhaps the 2011's are slightly different? I'm hoping somebody has an angled setup picture they would be willing to post?!?!
Old 12-11-2011, 07:25 AM   #6
Farrrrrr East Coast
my magnaflow is installed on the same angle as the factory was, my tail pipes lined up almost perfect...i think buddy is tryna gyp ya....i had 1.5 hr of labor 30 mins of that was getting the original off and 15 mins was trying to fix his welder...so its possible to do in about an hour
Old 12-11-2011, 07:25 AM   #7
Farrrrrr East Coast
i will get ya a pic of mine
Old 12-11-2011, 07:41 AM   #8
Thanks! Measuring the space between the inside of the output pipes is 1.5" Stock muffler is just over 2.5" By bringing it closer together to fit onto the Magnaflow would surely screw with the spacing at the tips....question is how much? My thinking is if they hanger off the tips close to the end at the tip outlet, and just bring the pipes together to match the Magnaflow, any change in spacing should be minimal at the tip....am I thinking correctly?
Old 12-11-2011, 08:14 AM   #9
Farrrrrr East Coast
this should answer your questions
Old 12-11-2011, 08:14 AM   #10
Farrrrrr East Coast
2
