03 exhaust manifold bolt broke - Hemi Truck Club
Old 01-02-2017, 02:54 PM   #1
Was changing oil today in my 03 and looked over the ehaust for a suspected exhaust leak. The back bolt on the passenger side is broke, i shined a lght up in the hole hoping the bolt had just backed out but it is broke off. How big of a job is it to replace ? Do i need to drop the inner fender to make it easier to get to ?
_________________________
Old 01-02-2017, 03:46 PM   #2
Removing the inner fender makes the job fairly straight forward. Shoot some penetrating oil on it a couple days before you pull the manifold helps.
Old 01-02-2017, 04:32 PM   #3
Thanks Greg,
Do i need to remove the donut gasket or will the manifold pull out far enough to do the job ?
Old 01-02-2017, 04:51 PM   #4
You will need to remove the manifold to get at the head, so yes. Stay with oem gaskets, but aftermarket bolts are recommended.
Old 01-02-2017, 05:19 PM   #5
Where is the best place to get the bolts ?
I may go ahead anddo both sides while i am into it. I noticed the drivers side has an aluminun heat shield but didnt see ne on passenger side
Old 01-02-2017, 06:24 PM   #6
The shields seem to fall off first... I did mine years ago and used some I already had. They look like ARP sbc intake manifold bolts. I remember I had to shorten them. I'm sure you don't want to go through all that. Call one of the forum sponsors, they'll know what's best to use on stock manifolds.
Old 01-24-2017, 04:17 PM   #7
Ok i got time today to tackle the broke exhaust manifold bolt. I pulled off the manifold and the only bolt that was broke was passenger side 1st one by the firewall. I tried welding a nut but it wouldn't take, so i decided to use a left hand drill bit. No wonder it wouldn't weld, it appears as if the manifold had been off before and someone filled the bolt hole with aluminum ! I drilled and tapped it enough to hold. Wonder why someone would do that ?
