what size is sts turbo - Hemi Truck Club
Old 06-04-2007, 01:32 PM   #1
im looking for a turbo and im trying to find the 1 in the sts kit but i dont know the size and everything if some1 could help me out on finding some used piping for it and a turbo that would help
DODGER 03 is offline   Reply With Quote
Old 06-04-2007, 01:56 PM   #2
It the Garett equivalent to a T4 but they won't say exactly what T4 is it. But rememeber, STS undersizes it. And the GT-67 upgrade is way too big unless you run between 10-15 psi.
Old 06-04-2007, 04:26 PM   #3
The base is a T60-1. The upgrade is the GT67. The GT67 is a 67 mm compressor wheel (750 chp) on a P trim turbine (76 trim). Both use a .96 AR.
I have run both with my 5.7. The T60-1 spools up a TAD faster but the GT67 makes more power even at 8 and 9psi and runs cooler EGT's. For stock engines with stock gears and converters I recommend the T60-1. If you have gears and a converter then the GT67 will spool up pretty darn quick.
Old 06-04-2007, 04:43 PM   #4
If you look at a compressor map, the gt-67 is too big unless you can run more boost and get the engine to take in more air.
Old 06-04-2007, 04:47 PM   #5
These hemi engines are pushing the air through. They flow like a formula 1 car. In most cases, I'd agree on the GT67 comment but having run both turbo's, I know what it does on this engine and it performs very well. The engine flow on this CI engine might be deceiving.
Old 06-04-2007, 04:48 PM   #6
And if you have a link to a GT67 compressor map shoot it over cuz I've been trying to find one. The GT67 is supposed to be a "custom STS" thing for their kits.
Old 06-04-2007, 05:14 PM   #7
It's not custom, everyone can get them from a Garett distributor. You have to size it up on like turbo calculator. You will have to know what boost and rpm range in what gears plus all the cfm numbers.
Old 06-04-2007, 05:31 PM   #8
kenihemi's Avatar
I think STS only has the GT turbos modified to handle the turbo surge with no damage.
Old 06-04-2007, 07:19 PM   #9
The T60-1 has been taking our engines to 400-450rwhp and then isn't "so" efficient after that. The GT67 is good through about 600rwhp. Since 7psi gets us to 415rwhp, the T60-1 IMO is on the virge of being optimally utilized.
But for a stock engine, the T60-1 is a perfect unit. And being that the GT67 uses the same housing, it's about $500 to have it rebuilt to the 67 if you ever build the engine to handle more power.
The T60-1 could push 30psi on a 4 cyl if need be. But engine flow and hp are part of the overall formula and 400 to 450rwhp is pushing the capabilities of that T60. Just so happens that 7psi is in that range for the hemi engine which starts to tap out that T60. I've had the T60 at 12psi and it didn't push the psi per HP increase that the GT67 does at that range.
Old 06-04-2007, 07:26 PM   #10
Just map it out and see the efficiency islands. They don't work out very good. I'm not saying it won't work, I am saying that is not the right size. It is too big.
