power loss - help! - Hemi Truck Club
Old 12-29-2007, 07:08 PM   #1
SFD90's Avatar
power loss - help!
hey everyone - i have installed a 3rd strike CAI about a week and a half ago and am noticing power loss upon take off. it seems to not want to go right away. i have reset the PCM both ways that i found on the forum. any input would be appreciated.
thanks
SFD90 is offline   Reply With Quote
Old 12-29-2007, 07:12 PM   #2
mudchucker's Avatar
power loss - help!
Do you still have the stock exhaust,.. after I installed mine,.. my butt dyno could really tell the difference.
Old 12-29-2007, 07:13 PM   #3
SFD90's Avatar
power loss - help!
yes i do
Old 12-29-2007, 07:15 PM   #4
SFD90's Avatar
power loss - help!
i definately feel more power in the mid range but the take off is a little slower now. also my mpg has been all over the place according to the overhead. have not gone through a full tank to do it manually.
Old 12-29-2007, 09:00 PM   #5
power loss - help!
You'll need to run a couple tanks of gas and check your mpg manually (don't rely on the overhead) to really see in there's a difference in the mpg after the mod.
I'm with mudchucker - you need a cat-back or at least a non-restrictive muffler to complete the "air in/air out" upgrade.
Old 12-29-2007, 10:39 PM   #6
madcat's Avatar
power loss - help!
how about the installation of your air density sensor? Did you note its installed direction when removed from the factory intake? If turned wrong, it could possibly be effecting your Air/Fuel ratio, resulting in poor bottom end performance...
Adding at least a cat-back exhaust will help as well
Old 12-30-2007, 08:59 AM   #7
D500's Avatar
power loss - help!
IAT sensors are very delicate. It doesn't take much to damage them and cost you mpg.
Check it out.
Old 12-30-2007, 09:20 AM   #8
SFD90's Avatar
power loss - help!
thanks for the help i did install the sensor correctly. i was really careful about that. i hope it is just a goof on the overhead. like i said i am still on the first tank so i cant get a true manual calc on the mpg yet. thanks again
Old 12-30-2007, 09:55 AM   #9
Freeze's Avatar
power loss - help!
quote:I'm with mudchucker - you need a cat-back or at least a non-restrictive muffler to complete the "air in/air out" upgrade.
Absolutely. The stock exhaust will create too much backpressure when paired with a good CAI.
SFD90, did you reset your PCM after the install? You might try pulling the negative terminal on the battery for about ten minutes. It'll erase your radio presets, but it will definitely reset your PCM. Hope it helps.
Old 12-30-2007, 12:09 PM   #10
The Original Bee
HemiSuperBee's Avatar
power loss - help!
quote:You might try pulling the negative terminal on the battery for about ten minutes. It'll erase your radio presets, but it will definitely reset your PCM
Not always, 1 hour or longer to completely wipe out pcm, been burned twice on that one.
