gauges - Hemi Truck Club
Old 09-11-2016, 06:18 AM   #1
gauges
What brand gauges is everyone running? Also which gauges do you have with you S/C or turbo setup? Last question are you using mechanical or electric gauges?
04 QC/SB stock cats with mufflers cut off right behind the X pipe…..much more to come in the future
04ramhemi4x4 is offline   Reply With Quote
Old 09-11-2016, 09:39 AM   #2
I use all electric gauges. Since there's not a lot of space for gauges I use a Aeroforce Interceptor to read most of the oem sensors. The others are AEM led gauges. IMO, the led lit gauges are nicer then the incandescent gauges. I like the important gauges to be easy to see and have them on the column. The boost and trans temp in the center of the dash. Added features of the Aeroforce gauge is you can set an alert (light) for any of the sensors it reads. I first had mine set to engine temperatures, now it's set for low knock. Plus along with gauges I use several led indicators. Efan on, od off, converter off, intercooler pump off and two indicators for w/m on. I use the low windshield fluid indicator for low w/m fluid. The Aeroforce Interceptor gauge reads two sensors at a time. One setting I use is to measure ambient air temperature and IAT inlet air temperature to see how well the intercooler is performing. Just plan and figure out what you want and where it will go. This will save time and money
Old 09-11-2016, 02:01 PM   #3
I use AutoMeter electric gauges, I have an A pillar mount, with an Oil Pressure Gauge, and an Transmission Fluid Temperature Gauge.
Old 09-11-2016, 08:16 PM   #4
I run the cheap glow shift guages for fuel and boost/vac for WIDEBAND I only use the AEM eugo WIDEBAND
Old 09-18-2016, 08:54 AM   #5
CharonBlk07's Avatar
I've gone through a few of the Glowshift gauges, I wasn't impressed with their sensors and their gauges gave me some issues as well, but that may have been electrical issues on that particular truck. I'm now running AutoMeter Elite 10 gauges for boost/vac, fuel, nitrous pressure, nitrous fuel pressure, AFR, and also a LC-1 for a second AFR.
'09 1500 QC/RB 4wd. Cog driven F-1A Procharger, forged 5.7L, W/M injection, 4.5"/6.5" drop, SQ audio system
CharonBlk07 is offline   Reply With Quote
Old 09-18-2016, 12:36 PM   #6
Lightbulb
It's usually hard to beat AutoMeter for gauges .
Old 09-18-2016, 08:36 PM   #7
That's what I have read. I was going to go with glow shift until I heard all the problems with them so I decided after reading about autometer and others that it's the better way to go
Old 09-19-2016, 11:15 AM   #8
I have an aem air/fuel gauge, when I get the chance to mod the truck more I'd like to add a one for oil, fuel, either boost or nitrous depending the route I go, an I'd say trans but meh the 545 is on given time anyway
