front mounted turbo - Hemi Truck Club
Old 06-04-2007, 07:18 PM   #1
front mounted turbo
does any1 have a front mounted turbo if so i need some pics please and i would jut like to hear what all i need to do that
DODGER 03 is offline   Reply With Quote
Old 06-04-2007, 09:41 PM   #2
&quotAv\sFan&quot
front mounted turbo
I thought you were looking at the rear mount in the other topic
Old 06-05-2007, 08:13 AM   #3
front mounted turbo
You'll need the same components with a front mount as you do a rear mount plus exhaust manifold welding to put the turbo.
The rear mount turbo's can run a smaller wastegate because the exhaust air is cooler making it denser. So you'll see basically the same flow through a 38mm wg rear mount as a 40mm front mount. The front mount will also need a higher AR than the rear mount IMO.
These engines really get into boost easy and you'll get uncontrollable boost if you're not spec'd right. A buddy of mine has a Turbonetics T61 front mount but has to run a 1.15 AR to keep it tame in his engine config. lol. The rear mounts in the configs I've worked with have a .96 AR. I've talked with two people that either had or switched out to a .82 or .83 AR for testing and had an incredible spool up but the top end suffered.
Old 06-07-2007, 09:00 PM   #4
front mounted turbo
i really want the sts kit bu its to much. if yall can find a used 1 or give me so suggestions on what i can do for exhaust i can get the turbonetics t-61 for about 700 or 800 on ebay but i just dont know what to do about the other stuff, if yall can give me some info on what all i need to buy to run like 5 to 6 plbs of boost i would appritiate it
Old 06-07-2007, 09:34 PM   #5
front mounted turbo
The STS kit is actually priced very good. You'll be hard pressed to set one up your self cheaper. Not saying you can't, but they have a proven setup
sharadonper is offline   Reply With Quote
Old 06-09-2007, 10:34 AM   #6
front mounted turbo
If you can weld and get that oil pump STS uses you can built a kit for about $1200.
Old 06-09-2007, 02:38 PM   #7
front mounted turbo
There are plenty of aftermarket oil pumps that are identical to the STS pump. Most run about $250. Come to think of it, this pump isn't necessary for a front mount. The front mount oil line would come off the front of the block.
Old 06-09-2007, 03:19 PM   #8
front mounted turbo
I know that, but if you were to build a remote setup it would cost you about $1200 maybe more cause I get wholesale turbos, but not much.
