Comp. ratio chart. - Hemi Truck Club
Old 03-30-2013, 08:10 PM   #1
Comp. ratio chart.
Watch yer boost!
HTC.com Titan Killer Club
Member # 17
Old 03-30-2013, 08:24 PM   #2
Good info - thanks Jay!
Old 03-30-2013, 09:12 PM   #3
This chart must be in dynamic compression ratio to have any relevance.
Sold: 2003 Dodge Ram 1500
Old 03-31-2013, 04:59 AM   #4
Good info. Thanks Jay.
Old 03-31-2013, 08:51 AM   #5
Brother can you explain that a little.
Old 03-31-2013, 10:47 AM   #6
Of course! Static CR can only be change by mechanical means. ie, lower/higher cc heads, mill head, thicker/thinner head gaskets, deck block, piston configuration, so on.
Member # 17
Old 03-31-2013, 11:48 AM   #7
Sure. I know my engine's static compression ratio is low at 8.5:1, but I cannot use the 8.5 on the chart to compare with my target boost pressure. While the engine is running, the camshaft and engine geometry will dictate a dynamic compression ratio that most likely is lower. (and varying with engine speed). Wallace Racing has a simplified online calculator for this as do engine design softwares.
Old 03-31-2013, 03:58 PM   #8
Nice so mine being a 9.6 static is roughly a 17.5 under boost boy I like the edge I need more boost and head studs and my dei cryo unit
Old 03-31-2013, 05:50 PM   #9
Gotcha, I have never worked on FI, so I'm guessing FI street motors are looking to build max cylinder pressure and use a Med lift and wide lobe separation. Of course this also builds the hottest cylinder gases, which on the other hand might benefit from a little overlap to cool the cylinders some. LOL, I need to do some bench racing to figure a little what you guys are doing. My goals are to skip the FI all together and just build a 10:1 something motor. I really admire the work you guys are doing. Well done!
Thanks,
