I cannot get the pressurized line clip undone, it's a clip i havent seen before, would the fuel line fitting tools from Advaned Auto Zone Boys work on this?
Tank is not quite sitting on ground under truck
on blocks as to not put any bind on line or fitting, and cant get a real good look at it unless I could get that guy at the end of BeetleJuice to shrink my head.
This is a old post, sorry I didn't read it before pulling mine apart. I just replaced my 03 pump with an 05 pump and just squeezed the clips together with my fingers and it came apart. Pushed it back together and it locked in place without any issue. I would recommend removing as much gas as you can before dropping as the tank gets heavy. I used a floor jack to lift it back into place.
