Removing badges - Hemi Truck Club
Old 03-06-2005, 10:15 PM   #1
Removing badges
What's the best way to remove the badges from my truck? Posts: 21*|*Location: Spring Branch, Texas*|*Registered: 24 February 2005
finnuts is offline   Reply With Quote
Old 03-07-2005, 05:52 AM   #2
kenihemi's Avatar
Removing badges
Make a piece of fishing line around 14" long, then use it like a saw and cut between the badge and the paint.
Then take a remover like goo gone or prepsol or thinner to remove the glue and such.
I use a popsicle stick, cut in half and rub lightly so you don't mark the paint.
Sometimes a little heat from a heatgun or hair dryer helps, but do not overheat the paint.
Old 03-07-2005, 08:11 PM   #3
Removing badges
The fishing line works well. That is what I used, but I would recomend using gloves when you do it. I have found that WD-40 works excellent on the glue, and it does not hurt the paint. Posts: 17*|*Location: Louisville KY.*|*Registered: 05 February 2005
03hemi1500 is offline   Reply With Quote
Old 03-07-2005, 09:32 PM   #4
Removing badges
Thanks everyone. I appreciate the help! Posts: 21*|*Location: Spring Branch, Texas*|*Registered: 24 February 2005
Old 03-07-2005, 10:42 PM   #5
Officer Hemi
Removing badges
I don't recommend thinner at all, it will surely damage the clear coat. Use goo gone, they make a spray/gel that I used, it came out great!
