02-19-2012, 06:29 PM
#6
It's not a very difficult job if you are handy with a welder. It 'can' be done in 1 day but 2 is better.
What year is your truck? on my 04 I had no clearance issues between the grille and bumper but on Nathan's, the grille hit the rubber insert in the bumper as it rotated around.
The basic design is a pair of plates drilled to fit the lower radiator support bolt patern that come out and down a little to just behind the grille. I used 3/8 pipe to create a hinge and then come from the hinge up to the bottom of the hood withh 3/4 square tube with about a 6" piece extending backover the top of the upper radiator support. The hood is cut for clearance for the 6" piece and then welded to it. Cross brace the 2 uprights( I used 1/2" sqare tube). Remove the factory hood hinges and install a set of hoodpins in the cowl area and your done.
HEMI's and Wings
Nothing better for a Sunday Drive
Homemade front tilt hood with mini MOPAR Pro Stock Style hood scoop, Self made air intake, Carr Hoops steps, Glasscapes window treatment, AVS chrome taillight covers and in channel visors, custom dual exhaust with Dyno Max muffler and cutouts, custom 'hockey stick' graphics, SportMaster Tonnue cover,ECCO 80w Corner strobe Kit, VR3 Back up camera system, MOPAR Rear wheel well liners, Superchips3815,purple neon underbody kit and windshield washer LED's
