Claybar? - Hemi Truck Club
Old 04-06-2005, 11:57 PM   #1
Claybar?
Okay, I have to play stupid on this one. What is a claybar? How precisely is it used? Where do you purchase one? Thanks for all the help.
RedNeckHemi is offline   Reply With Quote
Old 04-07-2005, 12:11 AM   #2
Freeze's Avatar
Claybar?
It's a bar of clay...hehehe. Sorry, I couldn't resist. Mother's makes one, and it's supposed to be killer for removing contaminants and other crap from your paint in preparation for waxing.
Old 04-07-2005, 12:14 AM   #3
MoneyHSK's Avatar
Claybar?
Here ya go bud!
http://www.properautocare.com/car-care-kits.html
Claybar's remove paint contamination. Try this test. Wash and dry your vehicle. Place your hand inside a plastic sandwich bag and lightly run your fingertips over your car's paint. It should be smooth-as-glass. If the paint has a rough, gritty or pebble-like feel, you have some type of contamination on the paint. Polishing will not remove this contamination. Using a claybar prior to waxing will remove the contamination.
Paint contamination consists of tiny metal shavings from rail dust, brake dust and industrial fallout. This contamination affects all paint finishes and can cause serious damage when left untreated. Paint contamination can be felt as a "rough or gritty" texture on the paint's surface and can lead to tiny rust spots. This contamination can not be removed by washing, waxing and/or polishing.
Where does it come from?
There are three major causes of paint contamination:
1. Rail dust - produced from the friction of train wheels against railroad tracks. Over 70% of new vehicles are shipped by rail. Rail dust can contaminate a new car's finish before it even reaches the dealership. Anytime a vehicle is parked or travels near a railroad it is subject to rail dust contamination.
2. Brake dust - particles produced from the friction of brake pads rubbing against the rotor. This metal on metal friction disperses tiny particles of bare metal into the air and on the highway where it collects on passing vehicles.
3. Industrial fallout - another word for pollution, industrial fallout is a byproduct of our modern industrial age.
Testing for paint contamination:
After washing and drying your vehicle, put your hand inside a plastic sandwich bag and lightly run your fingertips over the paint's surface. It should be as smooth as glass. If your car's surface has a rough, gritty or pebble-like texture, it indicates the presence of paint contamination. This should be removed with a clay bar before applying a polish or wax.
Removing Paint Contamination:
There is no wax, natural or synthetic, or any chemical treatment that can prevent or protect against this contamination. Compounding with an abrasive polish may remove paint contamination but it can only be performed a few times before removing too much of the top, clear coat finish.
The best solution, a special clay bar, was developed in Japan nearly five years ago. This clay safely removes rail dust and industrial fallout by "pulling" it off the surface. It does not "cut" or perform any abrasive action normally associated with polishing or compounding.
The latest evolution in clay technology is BLACKFIRE PolyClay. These clay-like bars are made in the U.S.A. of entirely man made polymers. These bars perform all the functions of traditional clay bars but have a number of advantages:
1. Poly Clay does not dry out with age.
2. Poly Clay does not decompose with repeated applications.
3. A single non-abrasive grade works on all paint conditions yet is still clear coat safe.
4. Poly Clay is easier to work with. It pulls, stretches and refolds easier that normal clay.
5. Poly Clay leaves almost no residue on the surface making clean-up much easier.
How to use clay bars:
Clay bars should always be used on freshly washed, clean surfaces. Dirt on the surface could cause scratches.
Caution: Use only as directed and with an approved lubricant such as Blackfire Clay Lubricant to reduce friction between the PolyClay and the vehicle's surface.
Work on areas of about three square feet. Lightly mist the surface with the lubricant. Glide the clay bar across the lubricated area until finish is smooth and contaminants are removed. When used as directed in the conventional method of polishing, contaminants can be removed from the surface without causing scratches. When used as directed, there is no (0%) polishing force applied to the surface while the clay is grabbing the contaminants. Wipe the surface with a clean dry towel and continue in sections until the entire vehicle is complete.
As the bar becomes soiled, simply pull, stretch and refold to expose a new, clean side. When the bar becomes totally soiled (dark colored) discard it. A 2 oz. bar should clean at least 5 to 7 cars. Do not use a bar dropped on the ground
After claying, the surface should be as smooth as glass. Remove any remaining smudges with a clean dry towel. Microfiber towels like our Power Scrubber Microfiber Cloths are perfect for removing clay residues. Mist the surface with the lubricant if necessary to make the final wipe down easy.
Tech Note: Clay bars will not remove scratches, swirls, dull, oxidized paint or restore surface gloss. This is accomplished by polishing the surface after claying. Polishing alone will not remove paint contamination.
Polishing and Finishing:
After claying the surface, you have two options. If the vehicle's paint is in like-new condition (good paint gloss and no swirls), you can finish by applying your favorite wax or paint sealant. If the finish shows any swirls or lacks luster, polish with a swirl remover or finishing polish and then apply a final coat of wax or paint sealant.
Frequency of use:
Poly Clay will not remove paint or the clear coat finish. It can be used as often as necessary to keep the surface free of contamination and smooth.
Always apply a protective coat of wax or paint sealant after claying the surface.
MoneyHSK is offline   Reply With Quote
Old 04-07-2005, 12:23 AM   #4
*Damn*its*gotta*Hemi*
Claybar?
And these are available only online or can yo uget them at like Pep Boys , Kragens, Schucks, etc.
Old 04-07-2005, 12:24 AM   #5
Freeze's Avatar
Claybar?
Hey, Money, it's about time you started linking again!
Old 04-07-2005, 12:29 AM   #6
Claybar?
That woman of his is keeping him too linked for him to giving us those good links!! LOL Good to see ya post one of those.
Old 04-07-2005, 12:40 AM   #7
Claybar?
HOLY SMOKESES! Ask and Ye shall receive...I reckon. Thanks for the quick replies. to you Money, thanks(bubba)
Old 04-07-2005, 03:06 AM   #8
TooTallll's Avatar
Claybar?
yeah, what they said...
LOL...I like these new avatars. hehe
TooTallll is offline   Reply With Quote
Old 04-07-2005, 04:22 AM   #9
Claybar?
I have mo more questions!
Bones is offline   Reply With Quote
Old 04-07-2005, 06:50 AM   #10
5SpeedHemi's Avatar
Claybar?
Bones your right.. I had questions about clay bars as well ..not now. Doing it this weekend
