Water in tail lights - Hemi Truck Club
Old 01-11-2008, 11:17 AM   #1
hoover001
This is really annoying. My tail light assemblies keep filling up with water and causing a lot of burnt out bulbs. It looks like the lense is de-laminating from the backing plate and letting water in. The seals around the bulb holder(for lack of a better word, or maybe socket assembly would work)seem to be holding ok. Has anyone had any luck re-sealing the outter edge of the lense? I really don't want to buy after market tail lights or altezza lights because none of them really do anything for me. Please help.
Old 01-11-2008, 11:57 AM   #2
&quotRANCHER&quot
Are they facorty, or after market lights? My after market ones started leaking after a couple of years. I removed them and drilled a couple of holes in the back side, one at the top and one at the bottem. They would still fog a little on damp mornings but they worked alright, and the fog cleared up pretty quick.
Old 01-11-2008, 12:07 PM   #3
hoover001
They are the factory lights. I might try your remedy. Thanks.
Old 01-11-2008, 12:15 PM   #4
Hemi Steve's Avatar
I tryed sealing the seams, still had moisture problems.
I did what Rancher did and drilled two holes at bottom corners to allow air circulation and a drain.
It worked for me.
Hemi Steve is offline   Reply With Quote
Old 01-11-2008, 01:31 PM   #5
&quotCompa&ntildeero&quot
My after market E-bay specials aren't leaking yet.
Old 01-11-2008, 05:34 PM   #6
gottahemi's Avatar
My factory tail lights are doing the same thing. I'm gonna try ranchers solution this weekend.
gottahemi is offline   Reply With Quote
Old 01-11-2008, 10:06 PM   #7
Cipher117's Avatar
hey guys, will 05 aftermarket tail lights work on 06 trucks? they look like they'd fit and what i want i only see for 05 models
Cipher117 is offline   Reply With Quote
Old 01-11-2008, 10:10 PM   #8
hoover001
quote:My after market E-bay specials aren't leaking yet.
If drilling drain holes in mine does not work out I might just have to go on e-bay and take another look.
I just realized that this is post # 1959 and that just happens to be the year I was born!
Old 01-12-2008, 12:09 AM   #9
DAYTONA RAM
no problem so far 3yrs.
Old 01-12-2008, 08:04 AM   #10
&quotRANCHER&quot
Cipher
quote:will 05 aftermarket tail lights work on 06 trucks?
Yes they will! 03 thru 06 are interchangeable. The 07 and 08's have the same size light but with only 2 bulbs and different wiring plugs.
