Running Lights - Hemi Truck Club
Old 09-20-2013, 09:05 AM   #1
Running Lights
I own a 2006 Ram 1500. My running lights will not turn off when the truck is turned off. I presently pull the 50 amp fuse when I get out of the truck. Any ideas?
dglawson is offline   Reply With Quote
Old 09-20-2013, 09:12 AM   #2
Question
Maybe ? splice-in a single pole dash mounted toggle switch with an inline fuse for protection. Turn them on and off anytime you want to...
Old 09-20-2013, 01:08 PM   #3
ROLLING THUNDER's Avatar
Make sure your cargo light is turned off !
Old 09-20-2013, 11:20 PM   #4
NewBlue's Avatar
They don't turn off after5-10 minutes? Check for stuck relay (should be another one you can swap in to test, don't put the suspect one anywhere else though).
Good luck!
Old 09-21-2013, 09:15 AM   #5
My 03 manual shows battery to IPM 15a fuse which powers "Park Lamp Relay". The Park Lamp Relay is switched by the "Front Control Module" and the output from the relay is fused going to the lamps.
I would check the Park Lamp Relay.
Good luck
