Rear Brake Light Warning - Hemi Truck Club
Like Tree2Likes
  • 1 Post By HemiDriver
  • 1 Post By charged392
Old 01-13-2018, 09:51 PM   #1
Hi All,
I am seeing a "Brake Light Out" message on the EVIC screen for the right brake. However, the brake light works just fine. I disconnected the battery for about 30 seconds in the hope it would clear, but not to be. The light fixtures on the rear are factory LED. Something on the CANBUS is causing the alert, so I will appreciate any and all ideas of where to look. The alert is getting annoying.
Thanks,
HemiDriver
2014 RAM 3500 Laramie SRW 6.4 Auto Brilliant White,
Class V receiver hitch, B&W Companion 5th wheel hitch, AFE dry air filter,
Weather Tech Floor Mats, Hood Protector & Mud Flaps.
______________________________________________
God Bless all USA military and First Responders, past and present. Thank you for your service!
HemiDriver is offline   Reply With Quote
Old 01-14-2018, 06:00 PM   #2
Seen a few of these at work not ended up being new led boards for the lights.
Old 04-05-2018, 11:00 AM   #3
Update:
I discovered the warning is for the third brake light on the cab, although the EVIC shows it is the right brake light. We have a canopy on the truck that has its own third brake light, and I'm not too motivated to dislodge the canopy to get at the cab mounted light. I have read previously it could be the brake light switch, I may check that out and see if that's the issue when I get some time.
Old 06-08-2018, 04:57 PM   #4
Update 2: I removed the third light fixture from the cab and to my surprise, there are incandescent bulbs used in the unit. The bulb for the brake light was broken, I suspect from water intrusion. Since LED's are used everywhere else on the truck, I would have thought the third brake/bed lights would be LED too. Anyway, a new bulb fixed the issue.
Cheers!
Redtruck-VA likes this.
Old 06-08-2018, 05:11 PM   #5
HemiDriver likes this.
