power for bed lighting - Hemi Truck Club
Old 01-30-2016, 04:50 PM   #1
grown in Tx's Avatar
Where should i get power from to feed a led under my tonneau cover. Probly going with the fridge button to activate it so I'll need to tap into something that is always hot.
grown in Tx is offline   Reply With Quote
Old 01-30-2016, 05:50 PM   #2
Could you snake a power wire up through the corner post hole?
Old 01-30-2016, 06:12 PM   #3
It shouldn't be a problem. I think there's a under hood light, I'll double check wife gets beck in a few and if so I'll just tap into that wire and run one under the truck up into the bed.
Old 01-30-2016, 07:12 PM   #4
Gold-Member
kcd1369's Avatar
Do you have the 7 round trailer connector? If so, there is a constant 12 VDC pin on that.
Old 01-31-2016, 04:47 AM   #5
Yes i do, thanks
Old 01-31-2016, 06:16 AM   #6
Yes for the bed pull it off the trailer plug and snake it up thru the tailight area and out the inside under the rail.
Old 02-01-2016, 03:25 AM   #7
Perfect, thanks
Old 02-01-2016, 09:23 AM   #8
Lightbulb
Originally Posted by grown in Tx View Post
Perfect, thanks
If you want to go to the trouble there are pigtail adapters that will plug into your harness from your trailer light wiring to make it plug-n-play.
