Only one headlight working - Hemi Truck Club
Old 09-23-2012, 06:37 PM   #1
Bohica's Avatar
Driving tonight, I noticed that when I turned on the lights only the driver's side came on. I checked the bulb on the passenger side and it's fine. I even switched the bulbs to make sure that I had a good bulb in. I checked the fuse box and there is nothing labeled for headlights or anything that was blown that I could see. If there is anyone that can give me advice on something to check or a possible solution it would really help. Thanks.
07 SLT Quad Cab
Plenty of 'tasteful' mods
Bohica is offline   Reply With Quote
Old 09-23-2012, 06:37 PM   #2
Bohica's Avatar
07 SLT Quad Cab
Old 09-24-2012, 01:12 AM   #3
Farrrrrr East Coast
NewfieBullet's Avatar
do you have hid? ....either way do the battery reset worked for me.
Old 09-24-2012, 01:27 PM   #4
Bohica's Avatar
I tried your advice and did the battery reset, but was unsuccessful. After thinking about it some more, and since I know the lights are integrated with the PCM (for what reason, I will never know) I pulled the PCM fuse. I then turned the key to start, and back to off, replaced the fuse and now my passenger headlight is working again. Hopefully this is not a sign of future problems with the PCM, but for now I'm glad that things are back to normal since I am out of state. Thanks for the help, I appreciated the quick response.
07 SLT Quad Cab
Old 09-25-2012, 03:22 PM   #5
Bohica's Avatar
Figured I'd post again because now both of my headlights are out. I tried the battery reset, and pulling the PCM fuse again with no success. So I'm leaving the terminals off the battery overnight and hoping that it completely resets.
07 SLT Quad Cab
Old 09-26-2012, 01:09 AM   #6
Farrrrrr East Coast
not sure on the 07's but on the newer trucks theres no fuses the lights are controled by the fcm...think thats what its called...it controls few different things...its possible that could be bad or a loose connection
Old 10-02-2012, 01:02 PM   #7
Bohica's Avatar
Well both headlights are out and I'm getting the code B1630 which is passenger headlight circuit high. Not sure why or what caused this but it seems like the only solution is to bring it to the dealer and have them troubleshoot it for me.
07 SLT Quad Cab
Old 10-03-2012, 03:43 PM   #8
Bohica's Avatar
I officially had a dumb moment and checked everything but my HID bulb. Turns out it that it had burned out. This caused the computer to throw a code, and after clearing them I was able to get everything back to working order. Definitely embarrassing but at least it was a minor problem.
07 SLT Quad Cab
