Need wire color - Hemi Truck Club
Old 06-18-2008, 09:44 PM   #1
Phill's Avatar
Need wire color
for the back up lights. I'm looking for the wire under the dash so that I can tie it to my strobes. I want the strobes on when I'm backing to wake up some of the idiots in parking lots
Phill is offline   Reply With Quote
Old 06-19-2008, 04:53 AM   #2
1st HEMI's Avatar
Need wire color
I knew I should have downloaded the manuals when I had the chance. I think Byrd might have a book
Sorry Phill, Do you have the optional trailer plug? You can test one of those wires (with a meter) too see if you have power in reverse.
1st HEMI is offline   Reply With Quote
Old 06-19-2008, 10:20 AM   #3
Need wire color
Cant you just tap into backup light wire at the taillight?
Old 06-19-2008, 03:52 PM   #4
HemiByrd's Avatar
Need wire color
Phill, what year is your truck? I have the manuals for '03, '04, and '05.
Old 06-22-2008, 03:34 PM   #5
Phill's Avatar
Need wire color
Dave , the truck is an 04.
I could tap at the back of the truck (My back up camera is spliced into that wire) but then I would have to run a wire back into the cab, currently the switch and the power supply are both in the cab and if I don't have to run another wire thru the truck,I'd prefer not too.
Old 06-23-2008, 11:11 AM   #6
MikeHTally's Avatar
Need wire color
If you have a seven-wire harness, it's the center pin. As I recall, the wire is white/brn stripe.
Old 06-23-2008, 12:41 PM   #7
Phill's Avatar
Need wire color
I have the wire at the 7 pin id'd I'm looking for an under dash wire.
Old 06-23-2008, 01:10 PM   #8
HemiByrd's Avatar
Need wire color
Phill, I copied this from my '04 manual. Hope this helps.
Old 06-23-2008, 10:28 PM   #9
Phill's Avatar
Need wire color
Thanks Dave
Old 06-23-2008, 11:50 PM   #10
HemiByrd's Avatar
Need wire color
Since I had my pdf manual open I also copied the rest of the wiring for the rear lights. I'm hosting all these images on photobucket so I don't use up too much space.
