my passenger headlight is not working someone help - Hemi Truck Club
Old 09-29-2011, 03:25 AM   #1
Will25990's Avatar
Well I got a call yesterday from my mom she took it to the shop to get the hid's installed. Well they didnt do it cause my low beam on my passenger side wasn't working and they tried to figure it out no clue why it isn't coming on. But just 2 weeks ago my mom said she was driving at night it was working just fine. well the shop tested the wires and no power to passenger side but to high side even from the connector no power to passenger side anyone got some input on this cause im sending my truck to a shop to get looked at if i can avoid it be nice.
2003 Dodge Ram 1500 Hemi. A few mods... 3865 Superchip 91 tune. 8.2 Taylor shorties. NGK 5306. Stock 3.92 gears. Falken tires on stock 20's. K&N FIPK Intake. American Thunder DOSS Exhaust. Sonnaxx. A/F ratio gauge. Srt10 gauge cluster Pillar. Pacesetter Lt's and y pipe. Magnaflow Cats. 1/4 mile 14.340 1/8 9.102 times for right now :). Lot more to come!!!
Will25990 is offline   Reply With Quote
Old 09-29-2011, 03:25 AM   #2
Will25990's Avatar
Old 09-29-2011, 05:16 AM   #3
Retired BOD - Doug
RANCHER's Avatar
That's gona take someone tracing the wiring harness. Got to have a worn spot somewhere or bad connector.
Old 09-29-2011, 06:58 AM   #4
Will25990's Avatar
Yea that's what the dude said that was working on my truck he said he be able to work on it monday. If i was home i could get it done but im not so gotta pay someone to do it. I was hoping maybe something needs to just be repluged or reset.
Old 09-29-2011, 12:20 PM   #5
Retired BOD - Doug
RANCHER's Avatar
Wish I could be of more help Will. Could be that the harness came unplugged on that side. Wish I was closer.
Old 09-30-2011, 01:19 AM   #6
Will25990's Avatar
Yea thanks for the thought Doug. Well it goes to the shop Monday morning I deff let yall know what is wrong with it.
Old 09-30-2011, 04:08 PM   #7
Retired BOD - Doug
RANCHER's Avatar
Old 10-04-2011, 04:49 PM   #8
I'm not a expert on HId but I have had one car I installed them into,
sometimes one side would not fire inless I turned the lights on and back off.
Normally that is due to a bad ballast, If you can I'd pull the ballast and put the bad one on the the side that has been lighting, does anything change? if that light now does not work you'll know its just the ballast.
if you change the ballast and the light still works then most likely its a harness issue.. and I've heard of that happening to guys from time too time.
Hope this helps you out good luck with it
Even unpredictablity becomes predictable
Raven is offline   Reply With Quote
Old 10-05-2011, 07:50 AM   #9
Will25990's Avatar
Its not my HiD's its the low beam light which is a regular light bulb.The hid's work fine just that but theres a lampout n they moved the headlight to the other side n pluged it in n it worked. So idk my dad workin on it when he gets time cause they dont want to take it to a shop when it could be something easy. but they r takin out the hid's n see if they r causing anything.
Old 10-05-2011, 08:28 AM   #10
Retired BOD - Doug
RANCHER's Avatar
