Lighting Problem - (Lamp out) - Hemi Truck Club
Old 09-27-2011, 01:12 PM   #1
speedmaniac's Avatar
Here is what i got...
2003 - 1500 hemi auto 2wd
When I push the brake pedal
1. LH brake lights seem ok
2. LH reverse light is about 1/2 lit
3. RH brake lights ok
4. RH reverse lights not lit at all
When the Left Hand blinker is on
1. LH blinker basically works
2. LH reverse lights flashes at about 1/2 brightness
3. RH blinker functions correct
When the Parking/Head Lights are turned on
1. LH tails are 1/2 brightness
2. LH reverse light is 1/2-1/4 bright
3. RH seems ok
Some things I've done/checked
1. Tested new LH tail light assembly from known good truck = NO CHANGE
2. Swapped out the silver box attached to under hood fuse tray (same part number) = NO CHANGE
Anyone got any suggestions or anything?
Jeff Munson
S.W. Kansas
Facebook: http://profile.to/jeffmunson/
speedmaniac is offline   Reply With Quote
Old 09-27-2011, 01:12 PM   #2
3. RH seems ok
Jeff Munson
S.W. Kansas
Old 09-27-2011, 08:15 PM   #3
NewBlue's Avatar
In the old days, you'd get weird stuff like that happening when the grounds got messed up (the lampholders connection to the body). But I think now they run a ground wire (2 wires) to all the bulbs right?
I guess I'd start at the lights and check the harness and all connections and figure out how they are grounding the harness.
Do you have separate fuses for trailer lights on the 03? If so it shouldn't be the trailer wiring (if you have any).
I've also heard of some problems with the wiring and connections under the fuse block.
Good Luck!
