Light wiring Q&A - Hemi Truck Club
Old 07-29-2012, 11:04 AM   #1
David
ATXHEMI's Avatar
I have ordered new headlights with red halos and 2 20" red led light bars for behind the grille. My question is do yall run a relay or just direct to the switch? I've heard its better to use a relay so all the amp draw doesn't go through the switch. I ordered 2 switches, 2 relays and 2 fuse links. And one more question. Do yall run the power to the battery or splice in to a hot wire under the dash? Thanks for any advise in advance
Old 07-29-2012, 11:04 AM   #2
David
ATXHEMI's Avatar
Old 07-29-2012, 07:31 PM   #3
HemiByrd's Avatar
Definitely use a relay and a fuse. There shouldn't be any problem running the power directly from the battery.
Here's a diagram.
You could switch the ground to pin 86 and have the hot side of the coil (pin 85) connected all the time.
Old 07-30-2012, 04:29 AM   #4
David
ATXHEMI's Avatar
Cool thanks for the diagram
