Light Out...Can't Find - Hemi Truck Club
Old 10-18-2012, 04:47 PM   #1
Adam
04hemisportedt's Avatar
Anyone had the following problem: Light Out keeps flashing on the dash, goes off when brake pressed (but brake lights are fine), but for the life of me I can't find whats wrong. Nothing special lighting wise, have plasmaglow bi-xenon bulbs.
AEM Brute Force Intake
Custom Painted Headlights
Custom Plastidip Wheels
Spike Lug Nut Covers
Debadged
3" Exhaust w/ AT3030XL
UnderCover Tonneau Cover
Rhino Lining & Under Spray
Bully Dog Triple Dog Tuner
Old 10-18-2012, 05:07 PM   #2
Remove the rear tailights and Inspect the bulbs themselves look at the filament in the rear running lights and brake lights possibly a filament broke and fell connecting to next one or a filament is just barely broken and int working
Old 10-18-2012, 07:26 PM   #3
I had a mystery lightout. Checked and rechecked, nothing wrong. Finally one day the wife drove the truck down my driveway and I saw the driver side brake light flickering. Replaced the bulb which looked good and cleaned the socket. Fixed the problem, would not havx found the problem without some luck.
Old 02-23-2013, 11:39 AM   #4
spainy79's Avatar
This happened to me about 2 weeks ago. Was leaving work and as soon as I dropped it in drive the lampout light came on. Got home, shut the truck off, did some checking, started the truck back up and no more light. Hasn't been on since. No idea what caused it.
Lee
'04 2500 QC LB 4X4
spainy79 is offline   Reply With Quote
Old 02-24-2013, 10:21 AM   #5
TooCool's Avatar
I hate the lamp out light. lolol Light come's on and all the light's are working. (WTF) I've had it with my hid's. Turned out to be the ground on the hid's 2x. Redone the ground's and solved the problem. You could put your stock bulb's back in just to eliminate them as the problem. The 03's/04's and some 05's had issue's with the circut board's on the tail light's. It will cause an intermitten lamp out that will come and go. After you check the ground's, tail light bulb's and prong's they slip into (clean and tweek them closer together with a small screwdriver) if the problem persist try changing the DS circuit board. It's the one that has been the problem for a lot of other's. The board only cost $20 at Autozone or O'riely's.
Old 02-24-2013, 09:22 PM   #6
5.7 liters of freedom's Avatar
i had that issue with my 05, if the bulbs/cleaning don't fix it, I had to replace one of my rear light terminal boards($20 or so) its what your lights connect to
Dreams Live On Forever, Only People Die In Shame.
Westin nerf bars, BFG All-Terrain 285/70R17, Truxport tonneau cover, AVS Ventshades, AFE CAI, Recon LED Tailights and 3rd Brake light, OEM Foglight upgrade, Best mod of all-----My lead foot
5.7 liters of freedom is offline   Reply With Quote
